Blower Motor Will Not Work at All - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 01-25-2019, 11:45 AM Thread Starter
I have a 1997 F250 7.3 and out of the blue when I went to turn my heat on, the blower did not kick in at all. I unplugged the blower motor and probed the connector with the switch set to high to see if there was power going to the blower, and there wasn't (I also replaced the blower motor about a year go). I also checked the fuse in the cab for the blower motor and it was fine. I then probed the fuse location to see if power was coming to the hot side of the fuse and there was no power there either. My climate control vent selector still works, as well as the temperature selector, the fan speed selector does nothing though. Does anyone have any ideas for what I can check next?
Melamed555 is offline
post #2 of 7 (permalink) Old 01-25-2019, 02:58 PM
bugman's Avatar
My Photos: (12)
I haven't checked on these trucks but most vehicles switch the ground on these type of things. You also might want to check the blower resistor on the housing.
bugman is offline
post #3 of 7 (permalink) Old 01-25-2019, 08:07 PM
Calico5's Avatar
Does it NOT blow in all speed settings, or will it run on HIGH speed, but nothing on low & medium?
If that's the case, it's most definitely the blower motor speed control resistor module.
Usually on the blower housing somewhere. On the newer trucks, it's under the hood on the blower housing...
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #4 of 7 (permalink) Old 01-25-2019, 09:21 PM
Steve83's Avatar
This eliminates the resistor & control panel as causes since they're DOWNstream of the dash fuse:
(phone app link)
I'd start by checking the underhood fuse that serves this dash fuse. Find it using your owner's manual, or this site:
BBB Industries- Premium Alternators, Starters, Power Steering Products and Turbochargers | TSB's & Wiring Diagrams
The email you use to get access doesn't have to be yours or real. When you see the red WIRING DIAGRAMS button, click it.
If the underhood fuse is blown, post EVERYTHING else that's on that fuse, and start checking those things for damage that could have caused a short.
Steve83 is offline
post #5 of 7 (permalink) Old 01-25-2019, 10:14 PM
Calico5's Avatar
Ooops, sorry, guess I read right past that, LOL.
Disregard...
Al in SoCal
Calico5 is offline
post #6 of 7 (permalink) Old 01-26-2019, 09:37 AM
Patrick Feeley's Avatar
My Photos: (19)
Blower is powered by underdash fuse #1, which is powered by underhood fuse #15 (50A Maxifuse). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3” DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #7 of 7 (permalink) Old 01-26-2019, 02:24 PM Thread Starter
Thank you both for your replies and for the pictures. Prior to this issue I only had the high fan speed setting which made me assume the resistor was bad, I just never got around to changing it because I always used the high setting. But my problem now is that the fan does not blow at all in any position, including high.
I never checked the under-hood fuse because I had no idea it tied into the blower motor. I will check it today!
Thanks!
