The Bolt Holes Are Gone! - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 09-17-2006, 10:08 PM Thread Starter
Erikk's Avatar
My Photos: (12)
...I just got some bucket seats for the truck in my sig and the bolt holes for the buckets are not in the floor pan at all...not even capped. I have one bolt on each side that I can use. It had split bench before and the buckets are out of a 95 truck just like mine. Tomorrow I plan on drilling holes in the floor and bolting them in anyway but I wanted to hear from some of my technical advisers first (that would be you guys!) [img]/ubbthreads/images/graemlins/grin.gif[/img]
Just drill the holes and bolt them in or is there some unforeseen drama waiting just over the horizon if I do this?
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
1996 F-350, 7.3 PSD, SRW C/C, 240k
4X4 Manuel hubs, 4.10, E4OD #2,
Michelin 285/75/16 E
Did-it-myself (Tymar style) open intake
Strait 4" turbo-back exhaust
Erikk is offline
post #2 of 5 (permalink) Old 09-17-2006, 10:15 PM
Re: The Bolt Holes Are Gone!
I would add some large square back up plates on the underside.
Say 2"x2" 3/16" steel. That way there is a lot more meat to hold them from pulling through should the truck ever become wrong side up.
Rick H...
Pres Omaha Metro PSD Club
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
post #3 of 5 (permalink) Old 09-17-2006, 10:18 PM
kfjensen's Avatar
I would say make sure you dont drill into fuel lines, etc, been there, screwed that up [img]/ubbthreads/images/graemlins/cool.gif[/img]
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
kfjensen is offline
post #4 of 5 (permalink) Old 09-18-2006, 07:17 AM
milner351's Avatar
My Photos: (5)
I've had several seats in and out of trucks from about '88 through '95... even Taurus seats (won't do that again)
DEFINITELY be careful and use a drill stop if you have one, and, use some backing to span a large area with your new holes, even a big washer under the floor will not be enough in an accident to hold the seat in place. At least use some heavy plate, angle / channel, something to reinforce the area.
Strange that the floor wouldn't be common, that doesn't make sense, but, doesn't surprise me!
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
post #5 of 5 (permalink) Old 09-18-2006, 10:35 PM Thread Starter
Erikk's Avatar
My Photos: (12)
Gotter done! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Grade bolts and some 2" washers, drilled the holes and bolted them in. Had to get under the heat shield on the passenger side and that was the hardest part since the thing was riveted in some spots that were real hard to get to with a drill...
Thanks for the advice guys! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Eric
Erikk is offline
