CA Model Trucks? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-15-2006, 04:42 PM Thread Starter
CA Model Trucks?
How Can you tell if a truck is a California Model? and what is that anyway? good or bad?
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New, I've Added Cab Lights, and Heated Steering wheel, Also made the Aux switches always hot so I can turn on lights even if the truck is off
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 330k miles
Sold - 2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
post #2 of 8 (permalink) Old 09-15-2006, 05:00 PM
PSDfreak's Avatar
Re: CA Model Trucks?
California trucks have split shot injectors...easiest way to tell is to have a look at the fuel pump...it is right behind the fuel filter canister under the turbo. If there is a big black "star ship enterprise" looking disk hanging off the front of it, its a CA truck. It will be labled "Bosch" (its a pulse dampener) The CA truck injectors flow more fuel than the non-CA models.
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 8 (permalink) Old 09-15-2006, 08:35 PM
The black disc is the pulsation damper, is about 3.5" in diameter and is BEHIND the fuel pump on the fuel pump banjo fitting under the turbo.
97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
post #4 of 8 (permalink) Old 09-15-2006, 09:59 PM
So is flowing more fuel bad or good? And does anyone know any differances in the Canadian trucks?
alabamabuddog is offline
post #5 of 8 (permalink) Old 09-17-2006, 02:41 AM
Stock, the fuel pressure regulator is set to 70 psi instead of 50psi, has 120cc split shot injectors instead of about 90cc single shots. The California trucks make a little more power, especially after adding a chip. Supposedly the split shot injector engines are quieter but mine wasn't.
Only thing different in a Camadian truck over a Federal one is the Daytime Running Lights and metric speedometer I think.
masami is offline
post #6 of 8 (permalink) Old 09-18-2006, 04:11 AM
PSDfreak's Avatar
Sorry for the misinformation...Behind the pump is correct location for pulse dampener [img]/ubbthreads/images/graemlins/crazy.gif[/img] ... thanks for the correct Dave [img]/ubbthreads/images/graemlins/wink.gif[/img]
-Casey
PSDfreak is offline
post #7 of 8 (permalink) Old 09-18-2006, 11:48 PM Thread Starter
Thanks Guys Looks like mine is a Cali Truck :P
jchipper is offline
post #8 of 8 (permalink) Old 09-19-2006, 07:53 PM
THey started a little later than mid 1996 in the change from single shots to splits. My 96 PSD was made in late June and is a single shot. IT is also a California truck, but at the time they made mine, there was no difference.
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- BB Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner
mattymx is offline
