california model: split shots? - Diesel Forum - TheDieselStop.com
post #1 of 22 (permalink) Old 09-06-2005, 07:02 PM Thread Starter
my 96 from what i've been told could have split shot injecters. does anyone know how to read the vin# to find out if i have a CA model? my truck came from out west im just not sure if it was as far west as CA.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
post #2 of 22 (permalink) Old 09-06-2005, 07:27 PM
DaveBey's Avatar
My Photos: (203)
Re: california model: split shots?
blackcloud -- The easiest way to tell if you have a California emissions truck is by the PCM calibration code. There is no way just by looking at the VIN to determine if the truck came from California. If there is a DSO code on the Vehicle Certification Label, that may help narrow it down.
Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4
-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●APCM
250,000 happy miles
DZLJIM 3:16
- Hold my beer and watch this.~~
DaveBey is offline
post #3 of 22 (permalink) Old 09-06-2005, 07:33 PM Thread Starter
what is the dso code and where is the certification label? are you talking about the catylist label? sorry if this is a dumb question but i really dont know!!
krowell is offline
post #4 of 22 (permalink) Old 09-06-2005, 07:37 PM
crashmk92's Avatar
May sound kinda dumb, but I was told that the CA models were the only ones that had the power mirrors on our trucks. I've also heard them referred to as the "California Mirrors". I also know that you can definately tell the CA model by looking at the fuel pump, and if you have the Bosch Fuel Dampner behind your fuel pump preventing you from replacing the fuel pump without removing the turbo and the pedestal, then you have a CA model. Supposedly the CA models were the only ones with the BOSCH dampner.
1997 F250 HD 7.3L PSD E40D 4X4 ; Dana 60 Conversion, 4" Superlift Suspension, ProComp ES9000 Shocks, Skyjacker Steering Stab.,Energy Suspension Poly Shackle & Track Bar Bushings, DIY Baldwin open element intake, 285/75 R16 Yokohama Geolanders,,15w40 Rotella T, Valvoline Maxlife Mercron ATF, Power Services Diesel Kleen (cetane +6), Midland 77-120 CB w/ Firestik FL2 4' Antenna. 1900RPM @ 70MPH. 197000 miles
Truck Birth-Month : October, 1997
crashmk92 is offline
post #5 of 22 (permalink) Old 09-06-2005, 07:40 PM Thread Starter
well i have the power mirrors and will have to check for the fuel dampener. thanks
krowell is offline
post #6 of 22 (permalink) Old 09-06-2005, 08:18 PM
DaveBey's Avatar
My Photos: (203)
blackcloud -- The Vehicle Certification Label is on the drivers side door; it is the big sticker that has the VIN, axle code, paint code, etc. If there is a DSO code, it would be on the right side of the sticker.
97F250PSD4X4 -- I forgot all about the fuel damper on the California trucks; good call! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Fuel Damper, California Vehicles Only
The fuel damper is located behind the fuel pump and is incorporated to control fuel pulsing.
Fuel Pulse Damper, California Vehicles Only
1 - Fuel Pump Damper (California Only)
2 - Fuel Pump
3 - Fuel Supply Line
4 - Banjo Bolt
5 - Turbo Pedestal O-Ring Seal
Dave
DaveBey is offline
post #7 of 22 (permalink) Old 09-06-2005, 11:11 PM
non cal trucks also could have the power mirror option. Mine does and its not a cal truck.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #8 of 22 (permalink) Old 09-07-2005, 02:40 PM
Personally, I don't believe that the 96 Calif. trucks had the split shot injectors. As to if it was sold in Calif. go to carfax.com and enter the VIN number. Not sure of the cost but you can find out known history of the vehicle including date and where sold.
97 F350 XLT, PSD CC, DRW, E40D w/Banks Transcommand, 4:10, K&N Filter, Pyro,Trans,Boost Gauges, BD Exhaust Brake, Turbo Down Pipe
RW Randall is offline
post #9 of 22 (permalink) Old 09-07-2005, 03:44 PM
splits came out in 96.5
post #10 of 22 (permalink) Old 09-07-2005, 07:16 PM Thread Starter
ok thanks everyone it doesnt have a dso code so no splitshots!
krowell is offline
post #11 of 22 (permalink) Old 09-07-2005, 07:33 PM
Guest
Posts: n/a
Post deleted by JLester
post #12 of 22 (permalink) Old 09-07-2005, 07:46 PM
My Photos: (11)
That is ugly. I think I will try to make some inline pulse dampeners to put on each head to fix the pulse problem.
Greg
96 F250XLT,SC, PSD Hooked to a BTS Tranny, LWB 4x4 (4.10s), D60 Straight axle conversion, Isspro Triple A-pillar Guage Pack, Mag-HyTec Axle Cover and a few others.
Fishhook is offline
post #13 of 22 (permalink) Old 09-07-2005, 07:56 PM
Guest
Posts: n/a
post #14 of 22 (permalink) Old 09-07-2005, 07:59 PM
My Photos: (11)
I apreciate the offer and I will keep it in mind but I dont know if it will be worth taking the turbo off to put it in or did I hear wrong about that??
I also will have to totally revamp the fuel system to an electric pump if I go with the BDS stealth pump. Gotta save up a lot of coin before I do that though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Greg
Fishhook is offline
post #15 of 22 (permalink) Old 09-07-2005, 08:03 PM
Guest
Posts: n/a
