CC Rear Lock Actuator Removal Help - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-16-2019, 04:43 PM Thread Starter
So I have the dreaded dead door lock actuator. Looks like the actuator bracket is riveted to the side of the door. How is the actuator removed? Don't want to just start pulling and stuff. Or drill out the rivet. Does the motor unit just pull off the rivet mount? Ugh, so far down in the bottom corner, hard to tell what's going on.
Any help would be appreciated.
Also, as for a replacement part, if I can't fix this one, will this work? Here it is
Thank in advance!
1997 F350 Crew Cab 4x4, AT, 4.10, drivetrain is all stock. Toyo Open Country A/T 285/65-18 10-ply on Allied Renegade wheels. Snugtop shell. TYMAR Intake. Coated H-Max DP with 4" exhaust. Donaldson resonator and Cat had to be put to sleep. Just turned 62,000 original miles!!!! Best addition-Wildman chip- Phantom II gauges. Sonnax valve w/ Tri-C springs and Royal Purple in the trans with a supplemental fan on the Tru-Cool cooler. ATS intercooler with 1.0 turbo housing and clean pedestal, no EBPV. SuperSprings installed.
Glen5241 is offline
post #2 of 5 (permalink) Old 08-16-2019, 04:55 PM
Patrick Feeley's Avatar
My Photos: (19)
I drilled out the rivet on my 94 and then IIRC, I unclipped the rod where it attached. Get a mirror and a good flashlight to help you see what's going on. I going to guess that actuator will work. I used a factory actuator off a different vehicle and switched the rod from mine to the new one. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 5 (permalink) Old 08-16-2019, 05:01 PM Thread Starter
Patrick
How did you mount the replacement motor after drilling out the rivet? Bolt with a nylock?
Glen5241 is offline
post #4 of 5 (permalink) Old 08-18-2019, 09:01 PM
My Photos: (19)
Honestly I can't remember! I would have used a 1/4" phillips-head cap screw with maybe a nylock, but probably a regular lock washer and nut. Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #5 of 5 (permalink) Old 08-19-2019, 09:05 AM
Steve83's Avatar
(phone app link)
Steve83 is offline
