check eng light no power runs rough - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 11-07-2006, 07:32 PM Thread Starter
My Photos: (22)
I was driving home this evening and my check eng light came on the started running rough and not enough power to hardly move the truck. Was sitting at stop light and check eng light went off and started running fine. It keeps coming on and going off with the same simptoms each time. I hooked scanner up and cant get any codes out of it to give me even a place to start thanks matt [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1995 f350 four door dually 5 speed 7.3
954doorf350 is offline
post #2 of 17 (permalink) Old 11-07-2006, 07:36 PM
PSDfreak's Avatar
Re: check eng light no power runs rough
If your check engine light came on there ARE codes on the PCM...what kind of scanner are you using? Does it have a chip?
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 17 (permalink) Old 11-07-2006, 07:44 PM
My guess would be the wire harness under the valve cover.I had the same symtoms and these guys diagnosed it and even told me how to figure out which side it was on.Get it scanned first if you can though just in case.Good luck,Calvin
1996 F-250 2wd, ext.cab, short bed, auto trans., 3:55 ratio, 3 inch DPP down pipe, 4 inch stainless Magnaflow exhaust, "Baby Swamps", TS performance 4 position chip, Tymar air filter, coolant filter, and HPX hose.Autometer gauges(pyro.,trans.temp.,and boost), California FPR kit, gutted and plugged EBPV, ported hood & bug shield, 203 Dieselsite thermostat, Extreme spray in bed liner, Wade bed caps, UAW black diamond plate under rail tool box, 4R100 trans.pan & filter, LARGE Hayden trans.cooler, Diamond headlights, park lights and side marker lights, Mustang GT hood scoop,Clarion CD player,Kenwood speakers.Billet Torque converter, Extreme duty trans.build with Transgo "Tugger" kit, Banks Technicooler, CCV Mod., Bilsteins, S.D.HPOP.
Calvin1958 is offline
post #4 of 17 (permalink) Old 11-07-2006, 07:50 PM Thread Starter
My Photos: (22)
using snap-on scanner that i have used in the past to get my codes but none there this time matt
post #5 of 17 (permalink) Old 11-07-2006, 07:54 PM
PSDfreak's Avatar
hmmm, thats odd that you arent getting any codes...I would pull the oil cap off and smell for burnt electrical...and you can inspect the 4 VC harnesses (2 per side) for burnt/melted plastic
-Casey
PSDfreak is offline
post #6 of 17 (permalink) Old 11-07-2006, 08:01 PM
Which Snap-On scanner?
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
post #7 of 17 (permalink) Old 11-07-2006, 08:11 PM Thread Starter
My Photos: (22)
no burnt plastic on any of the 4 conectors matt
post #8 of 17 (permalink) Old 11-07-2006, 10:15 PM Thread Starter
My Photos: (22)
Should i pull vavle covers and look at the wireing anyway ? matt
post #9 of 17 (permalink) Old 11-07-2006, 10:28 PM
kfjensen's Avatar
Naw, but make sure there is nothing burnt in any of the plugs AT ALL, even the slightest could cause the injector wire to be burnt and to run crappy, check again but if those arent burnt I wouldnt worry bout pulling the covers, correct me if I am wrong guys
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
kfjensen is offline
post #10 of 17 (permalink) Old 11-07-2006, 10:45 PM
I agree with 94. If theres no burn leave the covers on. I would use a different scanner. I'm not sure why a Snap-On wouldn't read the code. Anyway go back to square 1. If theres a Check Engine Light or CEL there is a diognostic code in the PCM.
krowell is offline
post #11 of 17 (permalink) Old 11-07-2006, 11:27 PM
Nit
exact symtoms of a burnt harness , most of then burn inside not out, I can not think of anythign else that makes teh truck act like that, buy yourself a harness tehn pull a cover and look.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
post #12 of 17 (permalink) Old 11-08-2006, 10:02 AM
I had the exact same thing happen to my 97. Engine went
flat, with CEL on. Ran on snap on scanner but no codes
other than I think P1111 system pass. Happened several more
times, and I noticed that if I kept my foot on the throttle
that the CEL would stay on. As soon as I let off, CEL went
out and it came back to life. Was thinking it might be either
the idle validation switch or TPS. Might look in this area?
My problem went away on its own so I'm not 100% sure that
was it.
good luck, and let us know what you find.
Brent.
<font color="green">97 F-350 4x4 crewcab PSD</font>,5 speed manual, 3.55 L/S
westin bars, lund super-visor, uniden cb custom
mounted in the ashtray opening. all stock for now.
other rides;
<font color="green">71 F100 4x4</font> 4.10 L/S, 428 CJ, NP435,NP205 T-case
dana60 rear,44 frt with big hub conversion.35" BFG radial muds on polished A/R outlaw wheels
total body off resto.(money pit)
<font color="gray">76 F250 4x4</font> 390 auto.(plow truck)
<font color="maroon">93 explorer 4x4</font> (wifes grocery getter)
pwrstrok73 is offline
post #13 of 17 (permalink) Old 11-08-2006, 10:18 AM
Nit
what would a throttle problem have to do with rough running? neither situation is remotely related.
Nit is offline
post #14 of 17 (permalink) Old 11-08-2006, 11:07 PM Thread Starter
My Photos: (22)
Used another friends scanner and got codes p0264 Cyl 2 injector ckt low and p0344 cam pos sensor ckt intermitent. got the cam sensor one first changed it out and drove it 30 miles and it did it again and checked codes and got the cyl 2 injector ckt low so pulled the drivers valve cover and bam what do ya know the wireing harness and the gasket are both burnt. Question is would the wiring burnt make it throw the cps code? i have had intermitent problems with it just dieing going down the rod so think both finally just gave out thanks matt
post #15 of 17 (permalink) Old 11-09-2006, 10:05 PM Thread Starter
My Photos: (22)
What is the cause of this to burn up? I want to fix the problem of this happening and not have it happen again? bad coonection? glow plug bad? injector problem? thanks matt
