Cold start issue - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 02-13-2007, 05:32 PM Thread Starter
Cold start issue
I've got a small cold start issue. This morning I went out to start the pickup and it barely caught and idle like major crap for a few minutes and then died. I couldn't get it to start again and I just figured that the fuel had gelled up. I just got a chance to check the fuel filter and none of the fuel in there is gelled up but it still won't start. Is it possible that fuel could still be gelled somewhere else in the system and that is keeping it from starting?
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!!
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Strokerin is offline
post #2 of 14 (permalink) Old 02-13-2007, 06:00 PM
Re: Cold start issue
[/ QUOTE ]How cold are we talkin?....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 14 (permalink) Old 02-13-2007, 06:01 PM Thread Starter
-6, windchill of -20
post #4 of 14 (permalink) Old 02-13-2007, 06:28 PM
[/ QUOTE ]Do you have a tire guage to check the fuel pressure at the schraeder on the FPR? Not the best way to check but better than not.Also look in the filter & see how the fuel looks & to see if it is full.Did you try switching tanks?
Rick.....
post #5 of 14 (permalink) Old 02-13-2007, 06:34 PM Thread Starter
Don't have a guage on hand, but it ran great yesterday, don't know why the pump would go out over night. Fuel looked like it had just come out of the pump. Switched tanks with no results.
post #6 of 14 (permalink) Old 02-13-2007, 06:45 PM
[/ QUOTE ]Shooting in the dark here ...how good are the batteries , is it spinning over normally, all the fuses good, getting a WTS light..?....
Rick.....
post #7 of 14 (permalink) Old 02-13-2007, 06:59 PM Thread Starter
Wts light, batteries had the cable on them so I know its spinning fast enough, all fuses good...
post #8 of 14 (permalink) Old 02-13-2007, 07:11 PM
Excavator's Avatar
My Photos: (11)
Try turning key on to engage glow plugs but wait at least 60 seconds after light goes out and then try to start. The glow plugs keep heating up after light goes out for a while longer. You may have a week glow plug some where also
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #9 of 14 (permalink) Old 02-13-2007, 07:11 PM
[/ QUOTE ]Check the HPOR & see if the oil is still 1/2" or so from the top....You have to find out if you have fuel pressure, also ,,somehow...
Rick.....
post #10 of 14 (permalink) Old 02-13-2007, 07:40 PM Thread Starter
Glow plugs are new and I always wait at least 60 seconds on the first start of the day.
post #11 of 14 (permalink) Old 02-13-2007, 10:38 PM
jimzpsd's Avatar
Try jumping the GPR, take a jumper cable clamp and make contact to both large lugs on the gpr, leave it on for 45 secs., then see if it fire up any easier. If it does, time for a new gpr.
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's (sold it, has 328k miles)
2017 F-350 XLT, 4wd, CC, LB
jimzpsd is offline
post #12 of 14 (permalink) Old 02-13-2007, 11:57 PM Thread Starter
gpr is brand spankin' new also. And I know the plugs are kicking on because the voltage drops.
post #13 of 14 (permalink) Old 02-14-2007, 12:14 AM
Nit
stop waiting 60 secs, wait 20 and crank it over, bet it starts better then, or better yet, jsut plug it in at night.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
post #14 of 14 (permalink) Old 02-14-2007, 03:00 PM Thread Starter
Got it going. Looked at getting a new cord for the heater but at almost $60 I figured I would play with it a little before I spent money on something I could fix. I knew the problem with the cord was at the plug, so I bought a new plug and put it on, plugged it in for a while and after a bit of cranking it fired up and ran. I'll check the fuel pressure at idle later this afternoon. Thanks to everyone for tossing out ideas.
