Coolant Drain Plugs - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 03-04-2009, 11:29 AM Thread Starter
Coolant Drain Plugs
I am in the process of doing a complete flush and drain of the cooling system. Does anyone have any tips on removing the 2 drain plugs on the block? They have never been removed (86k orig miles). I read Gooch's flush procedure (but his is a Superduty with 2 of the 1/4 inch ext. plugs) The 95-96 have 1 of the 1/4 inch ext plug by the oil filter and 1 bolt type plug by the starter. Could this be a nightmare trying to get these out for the first time?
Thanks.........
96 F350* CC*SRW*LB* 4X4* Auto W/4.10's* 97k mi.* 4" Magnaflow* AFE stage 2* Isspro pyro,boost,tranny guages* BD Valve Body* BD Exhaust Brake* Bilsteins*IDM Mod*Banks IC
TW tunes
Looking forward to: BTS*t500*AC stage 1's
cupins is offline
post #2 of 2 (permalink) Old 03-04-2009, 12:58 PM
get a couple 3/8" drive sockets that'll fit and a good size 3/8" ratchet and they'll probably come right out. if you take the block heater out of the oil filter housing you'll be able to drain a little more out there too. I don't know what Gooch's procedure says but I think you have to take the starter off on the pass. side.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
