Died driving, no start, oil in filter housing? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 17 (permalink) Old 08-16-2018, 11:45 PM
ArcticDriver's Avatar
Originally Posted by okney1lz View Post
Still running a little rough, I assume because of the fuel issue. However the fuel in bowl is clean, so my thought is contamination, not injector o-rings.
For right now, I'll focus on changing fuel filter ever fill up for a while, just to keep everything clean, and monitor my fuel pressure as it's still a bit low. Probably because of crap in the lines and selector switch.
If that is contaminated fuel and not oil on your old filter then you are going to need to drop the tank.
Changing filters will not fix that.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #17 of 17 (permalink) Old 08-17-2018, 11:59 PM
I
You likely have air in the high pressure oil system - that happens when you pull the IPR. Just drive it hard and it will work its' way out.
Be sure you drain your fuel bowl before you pull the filter, otherwise you risk getting that trash into your injectors.
Kimber1911 is offline
