E40D Transmission Engages Gear But Won't Move - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 09-26-2016, 05:16 PM Thread Starter
Hi Guys,
I've got a 1994 F-250 Powerstroke with an E40D Trans. Once the truck is fired up and I go to shift into gear, forward or reverse, it engages the gear but won't actually move. You can feel the truck lurch in the direction of the gear but thats it, feels like there a chock under the wheel. In the past I've been able to give it some throttle and have it pop into gear but no luck now. The truck has been parked on side hill with the drivers side lower than the passenger for about a month.
This was an ongoing issue last year due to a leaky gasket on the transmission but since I replaced that it hasn't come up again. Any ideas? I've add a bit more fluid but don't want to overdo it.
Thanks!
Sea_F250 is offline
post #2 of 24 (permalink) Old 09-27-2016, 05:40 AM
Can't help, but the 94's didn't come with a Powerstroke. Will it move in reverse? Mark the tranny guy here told me if it won't move in forward, but will in reverse the forward clutches are fried. $3,000 later, I'm rolling with a reman Ford tranny.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #3 of 24 (permalink) Old 09-27-2016, 07:44 AM
chuckster57's Avatar
Actually '94 had 3 different engines. 8th character of VIN tells you which one:
M is IDI non turbo
K is IDI turbo
F is Power stroke
chuckster57 is offline
post #4 of 24 (permalink) Old 09-27-2016, 08:27 AM
And the Powerstrokes of that year were all manuals. Also, model year and build date are not the same, so check the 10th character of the VIN as well.
Your issue, however, may not depend on what engine is in front of the tranny. First question is, what's behind the tranny. That is, is it a 2WD or 4x4 truck?
madpogue is offline
post #5 of 24 (permalink) Old 09-27-2016, 10:04 AM
I thought the 94.5 were hand shakers, but wasn't sure. Thanks for confirming!!
post #6 of 24 (permalink) Old 09-27-2016, 10:07 AM
bugman's Avatar
My Photos: (12)
But with 20+ year old trucks you never know what someone may of done to it.
bugman is online now
post #7 of 24 (permalink) Old 09-27-2016, 07:04 PM
True, Bugman. But...if he has a 94.5 converted to a slush box, it'd be the first time someone went backwards in transmission.
AaronSEIA
My Truck:
DIY intake
Kingpin Dana 60
otherwise stock
post #8 of 24 (permalink) Old 09-27-2016, 07:22 PM
bugman's Avatar
My Photos: (12)
I have actually seen quite a few post requesting information of going from a ZF to a automatic.
post #9 of 24 (permalink) Old 09-27-2016, 07:35 PM Thread Starter
Your guys know your stuff. It's a '94 with the IDI turbo engine. 8th number in the VIN is K.
It's a 4x4 and won't shift in forward or reverse in 4x4 or 2x4. This was happening every few weeks when I had the transmission gasket leak and once the fluid was topped off it would fully engage and move after giving the engine some throttle it would pop hard into gear. The gasket has been fixed and a put in an extra 1/2 quart of fluid yesterday but I still can't get it to pop into gear.
Sea_F250 is offline
post #10 of 24 (permalink) Old 09-27-2016, 10:51 PM
Could be the MLPS is defective or the connector is all corroded.
MLPS is (Manual Lever Position Sensor). The Clip that holds the Lever to the serrated adjusting plate could be broken, that would cause the MLPS not to move. New MLPS is about $57.
92 F350 Lariat, 2WD, Dualie, CC, LB, E4OD Trans, Banks Sidewinder turbo, GV O/U, Pyro, Boost, Oil temp, Trans temp. Chassis 129K, Engine 7.3L 75K. Bench seat.
"99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
ScanGaugeII SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
IDI firing order 12734568--------1&4-2&5-7&6-3&8 Cyl's @ TDC. 1&4 TDC when timing mark is @ 0. Each 1/4 turn, next 2.
Trucker87 is offline
post #11 of 24 (permalink) Old 09-28-2016, 06:17 AM
Mark Kovalsky's Avatar
My Photos: (6)
A bad MLPS cannot cause this problem. I can't come up with anything in the trans that can cause it. I'm leaning towards the problem being in the transfer case, axle, or the brakes.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #12 of 24 (permalink) Old 09-28-2016, 07:56 AM
If the MLPS was wacko wouldn't it just put the trans in limp mode?
Since it's a 4WD, the transfer case needs to be engaged, right?
post #13 of 24 (permalink) Old 09-28-2016, 01:39 PM
My Photos: (6)
If the MLPS is bad the trans will still engage first and reverse just fine, and it will move forward and reverse. There is no way that the MLPS can prevent that.
Mark
Former
post #14 of 24 (permalink) Old 09-28-2016, 04:25 PM Thread Starter
Any recommendations on how to narrow down these options? I don't think it's a brake issue so I'd start with the transfer case or axle.
Sea_F250 is offline
post #15 of 24 (permalink) Old 09-28-2016, 06:00 PM
Just for S&G, have you tried 4LO?
madpogue is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
themule67
