E4OD service questions & more. - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 01-28-2010, 07:48 PM Thread Starter
unowhoseattle's Avatar
Hello,
I am sending my poor old 1997 7.3 in to the dealer ( Harris Ford ) to have a couple recalls fixed, ( CPS & some cruise control issue. ) I was thinking about having them do a couple other things just because I don't feel like laying on the cold ground & my garage is too fill of junk to work inside. The truck has 208K on it & I have no idea when the E4OD or differentials were serviced. They recommended that I DON'T change the tranny filter, just the fluid for some reason. I have not had any tranny issues so far, but I know the fluid has at least 70K on it. What valid reeason would there be to not change the filter? Also, they want $230 to change the rear diff fluid "because the limited slip lube is expensive" That sounds like a real ripoff to me; is it? Napa additive was like $8.00.
The reason I am finally addressing the recall issue was because the truck started acting up. At first there was a tiny stumble when you first touched the accelerator. So subtle that I wasn't sure it wasn't my imagination. This happened maybe 3 times in a couple months. Then the other day the engine cut out for just a fraction of a second, so fast I didn't get a chance to react or look at the tach. The fuel filter is fresh & I don't have water in the fuel. Yesterday the engine cut out & in two or three times within maybe a second. This time I was able to see the tach jumping all over. I am hoping that this is the CPS. What do ya think?
Any comments or opinions are greatly appreciated.
If anyone can recommend a trustworthy service center in the Seattle area, I would love to find someone to do some maintenance and maybe fix my sagging front end.
Thanks for your time.
unowhoseattle is offline
post #2 of 8 (permalink) Old 01-28-2010, 11:36 PM
Patrick Feeley's Avatar
My Photos: (19)
The engine issue sounds like classic CPS. The rear diff oil change cost is steep, probably more due to labor than anything else (there's no drain plug so you have to remove the cover, scrape off the sealant, and reseal and wait for cure). The factory limited slip additive is around the same price. Even with full synthetic gear lube its not that expensive. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 8 (permalink) Old 01-29-2010, 10:57 AM
blageurt's Avatar
My Photos: (9)
Wait till it warms up and do it yourself. The money you save on those outrageous labor charges you can put towards Premium lubricants instead...
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
blageurt is offline
post #4 of 8 (permalink) Old 01-29-2010, 12:35 PM
I agree with Pat...that sounds pretty steep to me too on the rear diff. You could give Rob's Transmission Shop (425-392-5707) in Issaquah a call and see what they would charge for servicing the transmission and rear diff. I have never had any work done there myself but have heard good things from others who have.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #5 of 8 (permalink) Old 01-29-2010, 02:18 PM
When I did my rear diff, it called for 4 1/2 quarts of 75W-140, which ended up costing about $100 at Advance (5qt x $20/qt).
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
RD97 is offline
post #6 of 8 (permalink) Old 01-29-2010, 09:32 PM
pjwoolw's Avatar
My Photos: (5)
$20 a quart? What was it you purchased.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
post #7 of 8 (permalink) Old 01-30-2010, 12:09 PM
That must be some pretty good stuff to pay $20 a quart for it. I put Red Line in my rear diff and I thought $8 a quart was pretty expensive. Now I don't feel so bad.
Griz
Griz is offline
post #8 of 8 (permalink) Old 02-02-2010, 12:30 AM Thread Starter
Thank for your input, I decided to do it myself.
1997 F250 XLT SC/LB AT Powerstroke 4X4 all stock
