Exhaust Back Pressure Line - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-27-2009, 04:57 PM Thread Starter
I just noticed that my exhaust back pressure tube is broken completely in two about one inch off of the block.
Obviously this will affect the EBPV operation, but will this cause any issue with the turbo as well, such as lower than optimal boost, fuel mileage?
Thanks!
iwork4911 is offline
post #2 of 3 (permalink) Old 02-27-2009, 05:15 PM
That probably depends on how much, if any, exhaust is leaking out of the broken pipe. If it's stopped up with soot, then it won't affect much except the operation of the EBPV. I disconnected my EBPV at the electrical connection and plugged the hole in the exhaust manifold with a stainless pipe plug. So far it seems to work fine.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
RD97 is offline
post #3 of 3 (permalink) Old 02-27-2009, 08:56 PM
blageurt's Avatar
My Photos: (9)
Mine was rusted through when I bought the truck. The only reason I replaced the line was because I thought I needed it . If you live in a warm place then do as RD97 suggested. I like my EBPV because it works and I live in a cold climate. If you decide to keep it , the tube is only like 30 bucks from Ford . It is a bit of a PITA to install however.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
blageurt is offline
