FL oil filter - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 27 (permalink) Old 07-22-2007, 12:04 AM
My Photos: (10)
Re: FL oil filter
Just make sure that it is a lf691 and not a 691a; a lot of filters on ebay say they cross, but don't quite work.
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks
spaceballs is offline
post #17 of 27 (permalink) Old 07-22-2007, 12:18 AM
BlueMule's Avatar
My Photos: (12)
Re: FL oil filter
He's OK, He bought the 691's. I had been watching the same auction but forgot about it when it was time to bid.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...p;rd=1&rd=1
Rodney#33
BlueMule is offline
post #18 of 27 (permalink) Old 07-22-2007, 12:26 AM
My Photos: (10)
Re: FL oil filter
Ok; I just remember searching for these on ebay once and seeing some Baldwins that claimed cross to the 691 but don't for our trucks. I believe the 691 is a caterpillar filter and the 691 is only a small version of the 691a. I believe that the 691a would thread onto the boss, but there is just not enough room for it, nor is there enough room for the filter.
Kurt
SOLD!!
Tymar intake
post #19 of 27 (permalink) Old 07-22-2007, 12:33 AM
BlueMule's Avatar
My Photos: (12)
Re: FL oil filter
Right. The 691A has a larger diameter and wont fit next to our oil pans.
Rodney#33
BlueMule is offline
post #20 of 27 (permalink) Old 07-22-2007, 12:39 AM
Re: FL oil filter
lf691 is the small filter for a 3406 caterpiller I have used it on my psd before 691a is the bigger filter and is the one I use on my cat.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
post #21 of 27 (permalink) Old 07-22-2007, 09:45 AM
My Photos: (9)
Re: FL oil filter
Yes! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] Now you just need a new filter wrench to fit them.
I never use a filter wrench even on heavy truck engines. Never found it to be necessary. I just put them on by hand and take them off with a large pair of regular Channellocks.
Some mechanics use these (grip only on the top of the filter) but like I said I never found it necessary.
Birken
Birken Vogt is offline
post #22 of 27 (permalink) Old 07-22-2007, 10:16 AM
BlueMule's Avatar
My Photos: (12)
Re: FL oil filter
Channellocks work great in most applications. But in this case because the filter is nestled up between the oil pan,the crossmember, the frame rail and driveshaft the only good angle to get at it is thru the wheelwell. I find it's much easier to change it out from below, with the wrench, while on the creeper.
http://rides.webshots.com/photo/1133...54971087AnfUzH
Rodney#33
BlueMule is offline
post #23 of 27 (permalink) Old 08-06-2007, 10:51 PM
maloney's Avatar
Re: FL oil filter
i punch a hole in the bottom to drain the filter then just smash a skinny phillips threw her and im home free! (shade tree, i know)
-Black 1997 F-250 4X4 regular cab
-K&N intake/filter
-stainless Bully Dog 3" down pipe and 4" exhaust
-Tony Wildman chip
-Beans Stage I injectors
-Tru-Cool 4739 MAX transmission cooler
-A-pillar with Autometer gauges boost/trans/pyro
-Donaldson semi-truck oil filter
-John Deere coolant eye (thanks deeretrac)
-Bronco rear fuel tank (33 gal)
-Fuel tank vent mod
-160,000 miles
maloney is offline
post #24 of 27 (permalink) Old 08-07-2007, 12:31 AM
My Photos: (9)
Re: FL oil filter
I've tried the screwdriver a few times and sometimes it works but if the filter is really stuck you are sometimes left with a mess of shredded metal instead and then a real problem on your hands
Birken
post #25 of 27 (permalink) Old 07-31-2019, 02:12 PM
Buckskn's Avatar
I have 2002 f350 I was using the Donaldson oil filter which is longer I look led it it seemed to keep my oil a little cleaner but my sway bar would hit it and dent it these fleetgaurd look like they are the same is that true
Buckskn is offline
post #26 of 27 (permalink) Old 07-31-2019, 02:44 PM
ArcticDriver's Avatar
Donaldson’s are good quality.
I just use the Motorcraft FL-1995 for $10 at Wal-Mart.
SOLD:
ArcticDriver is offline
post #27 of 27 (permalink) Old 08-04-2019, 09:46 AM
I use the Motorcraft FL-1995s too. Been doing this since I bought the truck new in 1996. They seem to do very well.
MichaelPatrick is offline
