four wheel operation - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-23-2008, 09:38 PM Thread Starter
I had to go out and get stuck for the first time this year. After I got home, I noticed the 4x4 light on the dash panel remained on, even when the transfer case was not engaged. I crawled under the truck and checked everything, and all seemed in order. Any ideas?
97 F350 is offline
post #2 of 3 (permalink) Old 04-23-2008, 10:12 PM
jimzpsd's Avatar
This is a simple fix, all you need to do is replace the 4WD indicator switch w/a new one, it is mounted to the T-case. It is in front of the shifter pivot, forward side of the t-case. They normal "crud up" inside from lack of use, and the internal corrosion keeps it in the "on" position.
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's (sold it, has 328k miles)
2017 F-350 XLT, 4wd, CC, LB
jimzpsd is offline
post #3 of 3 (permalink) Old 04-25-2008, 08:25 PM Thread Starter
jimzpsd: thanks. $43 overnighted from Utah, and it only took about a minute and a half.
97 F350 is offline
