Fuel selector valve failed again? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Relentless007
post #1 of 10 (permalink) Old 06-17-2017, 03:29 AM Thread Starter
I put in a new oem tank selector valve and it worked fine for a couple months as far as switching tanks and gauge worked fine. Before the replacement it was stuck on front tank and reading full all the time (past full) the same symptoms have returned. Any ideas?
The truck is a 1997 7.3 diesel with about 500k on it.
I checked the tank selector switch at the dash and it switches continuity between the two terminals above and below the power feed wire. I cleaned the connections at the rear tank sending connection, cleaned connection at switching valve and another one along the driver side fuel line / wiring run and the the two connectors on the drivers side engine compartments wheel well close to the second fuse box.
Checked all fuses for continuity / voltage on both sides of fuse on both boxes.
Curiously enough it seemed to break the second time at the same time the fuse for the a/c blew and neither has worked since.
I have pored over many forum results and would be very grateful for any assistance.
Thank you
Cryghton23 is offline
post #2 of 10 (permalink) Old 06-18-2017, 04:47 PM Thread Starter
OK, responding to my own post.
Upon further research at the oilburners site.
I found that 3 month fsv failures are not uncommon with oem and aftermarket valves.
The general consensus is that this repeated failure or possibly the original failure stems from broken particles of the plastic tank pickup nozzle itself deteriorating. (its described as kind of a shower head looking thing) or other debris in the tank making its way into the mechanical workings of the valve.
Really had a hard time believing an oem fsv (fuel selection valve) that lasted 500k miles the first time would croak out so soon but it happened. Also the a/c is on the same circuit and has been reported to work again once the faulty valve has been unplugged.
An in line strainer would be a great idea but seems like a bit of work.
The valve can be found in many different ford vehicles between 1988-1998 which is great for the junkyard acquisition potential.
When the valve switches between tanks the connection for the fuel gauge is only accomplished with a full switch from a functional fuel selector valve so a bad valve will lead to a non read sensor.
Thanks for the help and hope this helps someone.
I will report back if anything changes.
post #3 of 10 (permalink) Old 06-24-2017, 01:07 PM
Many thanks for that report, Cryghton23!
I haven't had any selector valve problem yet nor have I had to drop my tanks. But if / when I do, I think I will eliminate the plastic showerheads in the tanks and leave the pickup hoses either bare or perhaps with a coarse metal pickup screen device on them.
Then, I would endeavor to plumb in-line filters between the tanks and the selector valve that can be replaced without dropping the tanks.
It does make sense that the selector valves are quite vulnerable to any debris they might encounter. The factory's answer to this was the showerheads which, ironically, too often have been found to be the source of the debris once they become old and brittle.
MichaelPatrick is offline
post #4 of 10 (permalink) Old 06-24-2017, 01:14 PM
Relentless007's Avatar
FYI;
If you leave the pick-up foot(shower head looking thing) off then the sending unit will not be able to pick up the last 3rd of tank. Thus once it gets below half a tank you better switch tanks or find a fuel station.
hammermill likes this.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #5 of 10 (permalink) Old 06-29-2017, 08:43 AM
That's true. I would put hose extensions in place of the shower heads and make sure they are long enough to pick up fuel at or very near the bottom of the tanks. Otherwise, too much fuel would be left unused and unusable in the tank.
post #6 of 10 (permalink) Old 06-29-2017, 09:11 AM
they are not terribly expensive and they to act as a layer of protection.
NEW Ford 1990-2003 2005-2008 Fuel Sending Unit Pick Up Screen Dorman 904-419 | eBay
BTS Valve Body
Tymar Air Intake
post #7 of 10 (permalink) Old 06-29-2017, 12:46 PM
OEM showerheads are available on Amazon for $34-ish. Our originals have by now lasted 20+ years, immersed in fuel that was not nearly as stable as what is being dispensed today. And since most of us are not first owners, we have no idea where POs might have sourced there fuel. I'm sure if you're careful about where you source your fuel, a replacement will last at least the 20+ years the original did, most likely a fair bit longer.
madpogue is offline
post #8 of 10 (permalink) Old 07-01-2017, 03:31 AM Thread Starter
Update : a "new" used fsv from the junkyard brought all fuel functions back online ( it was out of a 1993 diesel approximately.) Ford dealer swapped out the broken fsv for new under warranty.
Turns out the a/c needed a recharge which I just did off an ac/pro 20 Oz at home.
I was shocked when I looked at the receipt for the fsv and found I had paid $511 before tax.
Ohh the stealership.
I drew the oil out of the high pressure oil reservoir even after reading many folks speaking against the advice of the might Bill Hewitt and I must say it was a complete waste of time. Nothing sludgy or different about the oil in there. So +1 for leaving that part out of one's maintenance routine.
I put in some archoil in the reservoir but the 1997 reservoir does not "fill up" as far as can tell so it got a few more ounces than recommended before I noticed it was taking more than the recommended 16ozs
We shall see if that makes any difference with smokey starts and what not but with few miles I have driven it seems some positive results are coming from the archoil.
You'll have a great independence day and thanks for the help.
Luke
post #9 of 10 (permalink) Old 03-24-2019, 10:38 AM
is it worth the price of $320 for an OEM tank selector valve
or the $70 ones
post #10 of 10 (permalink) Old 03-25-2019, 10:46 AM
Audiowriter's Avatar
I have used a couple of the $80.00 aftermarket ones from O'Riley Auto parts and never had any issues. They lasted several years / miles and were doing fine when I sold the trucks. I have no idea if they are still working - now - several years later.
2 each - Stock - 97 F-350 7.3 PS 1 ton Duallys - RWD - AT
Audiowriter is offline
