Fuel tank switchover '1997 F250HD - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 09-13-2018, 09:28 PM Thread Starter
1997 F250HD 7.3 turbodiesel, where is the fuel switchover valve physically located and how does the system work?
boybowser is offline
post #2 of 4 (permalink) Old 09-14-2018, 06:05 AM
Audiowriter's Avatar
If your talking about the switch for the front and rear fuel tanks -
The solenoid is mounted underneath - on the frame, drivers side - about where the bed and cab meet.
When you select a tank from the rocker switch on the dash (Front - or - Rear) the solenoid moves to change which tank the fuel comes from (and returns to)
The solenoid has 4 fuel lines connected to it.
1 "pair" go to the front tank (suction line and return line)
the other pair go to the rear tank.
The solenoid "closes" one pair - as it "opens" the other pair.
2 each - Stock - 97 F-350 7.3 PS 1 ton Duallys - RWD - AT
Audiowriter is offline
post #3 of 4 (permalink) Old 09-14-2018, 09:19 AM
Steve83's Avatar
Actually, it has 6 lines: 2 for each tank, and 2 for the engine.
Steve83 is offline
post #4 of 4 (permalink) Old 09-15-2018, 06:56 AM
Oops, sorry - your right Steve83 - I forgot about the front 2 lines on the front side of the solenoid that go to the engine. I was thinking about the tanks only...
