GEM Module issue - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-22-2019, 11:30 AM Thread Starter
GEM Module issue
I have a 97 with a gem module problem. It will randomly hang the over cab lights on. The thing that’s weird is that I can park the truck and the lights will be off and then I’ll come back to a dead battery and once I jump batteries to my truck the lights are stuck on. The only way to turn them off is to jam a stick under the dash and tap the Gem Module.
1997 F350 XLT CC DRW LWB LS 4.10 Tow Package 6x4 Dark Blue Metallic, Auto, 7.3L
1FTJW35F5VEA10132
1999 F350 4x2 Oxford White w/ Grey Super Cab, SRW, L.B., 7.3 w/ Auto, Ltd. Slip 3.73, Cmpr Pkg., Factory Aluminum Rims, T/S Mir.
1FTSX30F3XEC85932
SprintCarCowboy is offline
post #2 of 4 (permalink) Old 03-22-2019, 02:20 PM
klhansen's Avatar
My Photos: (180)
The GEM module is a solid state device, so your percussive maintenance is probably affecting something else, like a conventional relay that's sticking. I would check for that before trying to replace the GEM (if you can even find one).
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 03-22-2019, 02:49 PM
bugman's Avatar
My Photos: (12)
The gem module would be real hard to find on a OBS truck, since they don't have one.
What are you tapping under the dash? I don't believe that there is even a relay under there that would control any lights.
bugman is online now
post #4 of 4 (permalink) Old 03-22-2019, 06:22 PM
Patrick Feeley's Avatar
My Photos: (19)
Keyless Entry Module maybe? Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
Similar Threads
GEM Module mikebosman25 1999-2007 General Questions 1 02-02-2016 01:13 PM
2011 6.7L DTC (Diagnostic Trouble Code) List... PowerStrokeHD 6.7L Power Stroke Engine and Drivetrain 19 03-19-2015 07:00 PM
New Vendor: www.TunerTools.com TunerTools New Member Introductions & Forum Assistance 1 12-10-2008 11:06 PM
Dead GEM Command Module? orf350 '99 & up 7.3L Power Stroke Engine and Drivetrain 5 08-27-2007 02:35 AM
