glow plug replacement - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-08-2009, 10:52 AM Thread Starter
169stang's Avatar
My Photos: (5)
Well, I replaced the glow plugs and GPR last night. Nice weather....in the 50's now! After reading alot of these threads, I thought it would take longer. It took me about 2 1/2 hours being in no rush. It was very straight forward. The driver's side was much easier. I was able to squat where the air intake sits. Uncomfy on the passenger's side!
I replaced the GP's, GP/injector harness's, valve cover gasket and GPR. I purchased the ZD-11 GP's off ebay for $60. Great deal!
Thanks to Dave Pharis (Believer45) for the emailed instructions.
My ONLY issue was not being able to get all the oil out that sat on top of the GP's. Maybe a teaspoon full trickled down after removing each GP. Should I have concern? It started right up after completion.
1997 F350 7.3L CC DRW 2wd
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
169stang is offline
post #2 of 5 (permalink) Old 02-08-2009, 12:39 PM
The problem with excessive oil getting into the cylinders is Hydro-locking or something like that. Since you didn't experience it I would say your good.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #3 of 5 (permalink) Old 02-08-2009, 01:25 PM Thread Starter
169stang's Avatar
My Photos: (5)
It should just push it out the exhaust valves....correct?
Also, I noticed the intake pipe to the turbo being wet with oil...obviously on the driver's side after where the breather element enters the intake tube. Is how much is too much? How do I reduce or stop it? Is there a breather mod people do with a catch can? Replace the breather itself? I'm curious how much oil I'm actually loosing through the breather.
169stang is offline
post #4 of 5 (permalink) Old 02-08-2009, 04:51 PM
My Photos: (61)
The crankcase vent is routed into the intake before the turbo so you will burn the excess oil that comes out instead of losing it to the road.
The oil that may have gotten into your cylinders is long gone, burned for additional fuel.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #5 of 5 (permalink) Old 02-08-2009, 07:12 PM Thread Starter
169stang's Avatar
My Photos: (5)
I'm really curious how much oil is blowing by.
BTW: I have the old GPR, GP's, valve cover gaskets and UVC harness's if someone wants them. Just pay shipping. I haven't tested anything to see if something was good or bad. I just replaced them b/c it was all original and I'm at 160K miles. I don't want any issues in my travels!
169stang is offline
