glow plugs not shutting off - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 16 (permalink) Old 09-19-2006, 08:31 AM
MarkEkberg's Avatar
My Photos: (13)
Re: glow plugs not shutting off
I provided a solid ground because I thought my pcm was not giving the solenoid the ground signal. After I did that to test everything seemed to work a little better and I could provide GP at any time I needed.
After that I had to change the switch to a momentary switch in cab becasue I almost forgot them on a few times.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
