Hello everyone - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 07-26-2018, 06:36 PM Thread Starter
Hello everyone
I need some help. I have a 1996 f350 7.3 turbo centurion crew cab with extended cab lwb 4x4.
A few months ago i had the truck idling in the yard when it shut off as if you turned the key off
After get several mechanics to check it out. I have replaced the cps,idm,ipr valve. Still not running. I now have checked the hpop reservoir and it was empty. Filled it and after a few times turning it over and letting it sit a few days it empty again . So now i filled it removed the icp and have very little oil coming out. And the reservoir and its empty, refilled cranked it over a few times and oil level dropped in reservoir again. So could it be the check valve or the lpop.
Sorry for the lengthy post.
Rreeves1967 is offline
