Help identifying alternator. - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-27-2009, 11:47 PM Thread Starter
unowhoseattle's Avatar
Hello,
My alternator on my truck has worn out.
It ate the brushes.
The truck is a diesel 1997 F250 LB 4WD SC with Ac & Auto.
I thought it would be simple to get one at NAPA or Autozone, but they claim there are several non-compatible versions and they can't seem to identify what I have by looking at it.
The truck is 100% stock & it worked fine for 200K + miles so a stock replacement is fine.
The only numbers I can find are on the bearing dust cap it has the marking "F6UUEA" and tiny numbers that might be "96091118"
The attached voltage regulator is marked "F5DU-10316-AA"
They need to order whatever I choose so I can't do a side by side comparison.
I Googled all these numbers & searched this forum with no luck.
I assume it 130 Amp?
Are they all interchangable?
Can anyone help me out with advice or a part number?
It has the triple connector plus single plug on top.
1997 F250 XLT SC/LB AT Powerstroke 4X4 all stock
unowhoseattle is offline
post #2 of 6 (permalink) Old 09-28-2009, 08:12 AM
Feedback Score: 3 reviews
should only be 1 option for 95-97 PSDS, some gassrs use the same one , just need to swap pulleys, it is 130 amp
Dads ride 2002 Dodge 24v, dual exhaust, edge comp hot box. tst 40 hp injectors,Piers B-1 turbo dipricol white face a pillar gauges, Suncoast triple disc and valve body occasionally he lets me drive it. 393 rwhp, 807 ftlbs
1996 F-350 CC swr, long bed , 4x4 PSD zf-5, 260k.Swamped, 5" black stacks, dipricol gauges, 30+PSI boost, DP tuner chip, 349rwhp.
95 PSD project fixes it up and then sold it
03 7.3 4R100 4x2(for now) 240k stock cept for duals 20th aniversary edition.
early 99 CC Dually,
finallygotanIDI is offline
post #3 of 6 (permalink) Old 09-28-2009, 09:02 AM
donthelegend's Avatar
Tell the counterperson it is a 96. In 97 and 98 there was a light duty f250 ( they should know that)
97 F350 4x4, rc, auto,4.10s, added some leafs, 35x12.50x16.5 BFG MT KM's/Weld alloys,Bilsteins, Banks git kit, Banks downpipe. test pipe, gutted ebpv. diy intake,shimmed fpr, mo ,diy intake, 36k tranny cooler, recalibrated speedo, banks pillar mount egt.& trans. temp gauges,homemade 3x6 rear bumper,front grill/brush guard,04 40/20/40 seats,
donthelegend is offline
post #4 of 6 (permalink) Old 09-28-2009, 09:54 AM
Zrock's Avatar
or you could always go to ford. Asking them for a price and a part # then they can cross refrence it
1995 F250 Powerstroke
Zrock is offline
post #5 of 6 (permalink) Old 09-28-2009, 10:20 AM Thread Starter
Thanks everyone for your help
Thanks everyone for your help.
post #6 of 6 (permalink) Old 09-28-2009, 10:35 AM
if you don't need your truck for a few days...take your alternator into a place that will rebuild it.
97 f250 4x4 ext cab tymar filter e4od 410 ts chip dp and 4" exhaust system
julyer is offline
