LinkBack | Thread Tools | Display Modes |
How many glowplugs
How many glowplugs can be bad and the truck still start? I got the plugs on the Passenger side changed tonight before it got dark. I only had one bad one on that side. I check them as I pull them out by hooking them directly to the battery with jumper cables. Now I have one better one than before and it still wouldn't start. I had replaced a bad one on this side last year as well and it started like a champ. I put a used one in though, that's why I'm just replacing them all with brand new this year. I'm wondering how many I will find bad on the driver's side tomorrow. I would guess all of them. Also, can anyone tell me the torque on the plugs?
1997 ext cab, long bed, 4x4, auto. Genuine Tymar induction. Retired F-15E Strike Eagle mechanic.
Sponsored Links | |||
Advertisement |
My Photos: (13)
Glow plug relay?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
My Photos: (61)
Mine was starting with difficulty but with four bad and one unplugged (three working glow plugs).
CLICK HERE to go to the thread I started when I did mine in October of 2001.
Dave / Believer45
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Advertisement |
It's not the GPR. I replaced it with a Stan-cor last year when I was having trouble starting and I verified it just to make sure. I also changed a plug on the passenger side at the same time last year because I had the valve cover off anyway. I didn't do the driver's side then. I finished replacing all of my plugs today and it turns out that 5 of them were bad (all four on the driver's side, one on the passenger's side). I have 8 brand new ones in there now so hopefully I'll be ok for a while.
Originally Posted by ctrout
View Post
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Advertisement |
outside pins fried - actually desintigrated - glow plugs?
Severe resonating vibration when I hit a bump with hubs locked in 2wd or 4wd
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Posting Rules | |
