How many miles on your PSD? - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 100 (permalink) Old 11-08-2005, 06:52 PM Thread Starter
I know this has probably been done before but what the hay,How many miles on your un-rebuilt PSD???
70 Barracuda Gran Coupe,383hp,#'s Match
2002 F250 SD Super Cab XLT,7.3,6 speed Manual,4x4
Suzuki Vinson 4x4 ATV
Ford 1510 Diesel tractor,4x4,loader
2012 Subaru Forester
2014 KLR650
2014 Polaris Sportsman 800EFI
moooboy is offline
post #2 of 100 (permalink) Old 11-08-2005, 07:16 PM
Re: How many miles on your PSD?
I just turned over 180,000 this past weekend. Still [img]/ubbthreads/images/graemlins/smokin.gif[/img]!!
JD
1997 F-250 Bad-Ass Black 4x4 Supercab Long Bed, E4OD Tranny, 322,000mi and counting, 4:10's, 75hp TS Performance chip, Shimmed fuel regulator @ 65psi, TYMAR intake, Gutted EBPV, TYMAR HPX, Hypermax DP & a homemade 4" straight pipe.
JDpowerstroke is offline
post #3 of 100 (permalink) Old 11-08-2005, 07:32 PM
233,000 and counting.
ART
2003 Ford Excursion...7.3, 4X4.
agsF2501 is offline
post #4 of 100 (permalink) Old 11-08-2005, 07:56 PM
I'm only at 170,000.
3" into 3 1/2 downpipe into 4" straight pipe exhaust
stroken96 is offline
post #5 of 100 (permalink) Old 11-08-2005, 08:00 PM
kfjensen's Avatar
Just break'n er' in at 100k right now....
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
kfjensen is offline
post #6 of 100 (permalink) Old 11-08-2005, 08:17 PM
Um, OK, this one wasn't mine, but it is the highest mileage powerstroke I have ever personally seen in person.
We had a rollback come in with 355,000 miles on it, needed a new motor because the guy ran it low on coolant and drove it like that for like 3 weeks. The block cracked and let coolant into 2 cylinders, he then checked the coolant level, and then had to keep refilling it over the next 5 weeks because it kept pumping the coolant out. Other than that, the motor looked excellent inside, most of the cylinders still had cross-hatching in them. We put a new motor in it.
Mine only has 86,000 now.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD
Mods: Swamps tunes, Swamps 275/226's, a Gen3, a BTS, Comps, Crowers and H11's up top, S465/TN II mount kit, Custom Comp. fuel system, and an IC.
smokyred is offline
post #7 of 100 (permalink) Old 11-08-2005, 09:10 PM
diesel97's Avatar
86,000 on mine [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2005 E-350 SRW CUTAWAY,6.0 DIESEL AUTO,ALLOYS 10FT KNAPHIEDE KUV BODY.SILVER POWER EVERYTHING.
97 F-350 XLT 4X4 7.3 PSD,99K AUTO ,REG CAB,GREEN,NOT STOCK
96 F-250 XLT 4X4 7.3 PSD 220K AUTO REG CAB,BLACK,BONE STOCK EXCEPT FOR A NEW CAR SCENT AIR FRESHENER.
#28
diesel97 is offline
post #8 of 100 (permalink) Old 11-08-2005, 09:24 PM
MLT65's Avatar
198,700...runs like a top.
, 4R100 tranny pan with drain plug, Motorcraft Premium Gold coolant, 4.10 gears, Westin grill guard and nerf bars, Monroe Reflex gas shocks, Monroe Magnum steering stabilizer, DeeZee toolbox, Powerflow splash guards, Wade bed caps, Ford bed liner, Bugflector II, Sylvania SilverStar headlights, Cooper Discoverer A/T tires, Eagle Alloy wheels, Energy Suspension urethane bushings, Tymar open element intake, Alpine 200 watt stereo, Kenwood 200 watt speakers, open exhaust with Ford SD "test pipe", MagnaFlow 4" stainless exhaust tip. 217,000 miles.
, 4" Trailmaster lift, Rancho shocks, 489,000+ miles, driven every day for 21 years until I got my PSD. (Still drive it when the weather is nasty)
MLT65 is offline
post #9 of 100 (permalink) Old 11-08-2005, 09:33 PM
319,000 , I am the 3rd owner , my brother had it since 120,000 till 220,000 , i have had it since. i am pretty sure the tranny was out before my brother owned it.
1995 f250 XL Ext Cab 4x4, auto ,3.55 gears , 317,000 miles , K&N filter , muffler Deleted ,Shimmed FPR, hypertech chip (a basic older one of unknown power) ,boost guage , small amount of leaf spring work done rest of is stock , steel wheels with hub caps , carpet delete. My old user name was Daveuz , UPDATE AS OF 11/05 new starter new waterpump LEFT ENGINE FAN OFF, new IPR new CPS replaced injector drive (used) all new under the cover harnessess and GPs and all this and my stalling problem was fixed by replacing the PCM , which I had DP Tuner flash in the 80hp econo. 12/28/05 cleaned the Cat Box UPDATE 12/06 334,000K NEW NEW NEW 11/06 1997 xlt CC LB 4x4 all white with a with topper. 285K all stock.
daveUza is offline
post #10 of 100 (permalink) Old 11-08-2005, 09:36 PM
Just turned 128K this week.
Ask Moremph, he has a couple pushing 300K
Craig
2000 Ford F250 Lariat 4x4 Auto SuperCab LB PSD
2L Motorsports transmission (Precision 3 disk converter, valve body, upgraded clutches), V10 tranny cooler, TS chip, MBRP 4" exhaust, 4" to 5" tip, Auto Meter Z Series Boost, Pyro and Tranny, Poor Man's DIY intake, Boost Relief Valve, Crank Case Vent routed under truck, AIH plug
Both powered by 2L Motorsports
2L Who??
CraigPSD is offline
post #11 of 100 (permalink) Old 11-08-2005, 09:41 PM
257k here, no rebuild and uses less than a quart every 3500.
1995 F350 PSD 4x4 Reg Cab LB 5 speed. Babies, 6 po chip, Southbend OFE, Autometer Ultra-Lite EGT, Boost, Oil Pressure, Poor man Tymar, 3" downpipe, cat delete, 4" exhaust with muffler, 4.10 gears, Bilsteins, crushed white with pearl clearcoat, all black interior with tan Eddie Bauer seat. SOLD 12/06
2003 F350 King Ranch 4x4 6.0l powerstroke CCSB
AFE stage 2 Pro Dry S
4" Turbo back Magnaflow
95PSDF350 is offline
post #12 of 100 (permalink) Old 11-08-2005, 09:49 PM
188,000 doesn't burn any oil
- Jordan
96 f350 7.3 206kmiles 4x4 stage 1's downpipe and gagues.
jray3369 is offline
post #13 of 100 (permalink) Old 11-08-2005, 10:08 PM
rolled 184,000 today on the way home from work and still smokin! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
96 f350 powerstroke 5 speed manual tranz. crew cab extended cab long bed dually and yes you read this right.mods 3"downpipe,4"exhaust,gutted ebpv,tymar air intake,water temp, boost guage,egt guage on a-post,shimmed fpr,Stage-1 diy injectors,beans 6 position chip,and looking for new things to try for more power!!!!
becky is offline
post #14 of 100 (permalink) Old 11-08-2005, 10:12 PM
119,000
1997 f-350 4X2 7.3 PSD E4OD AUTO 4.10 Rear CC Dually Run Rotella Synthetic Oil, 150,000 +/- Miles...Came with a Superchips 1705 programmer....Things I've had to do ....Left Front Ball Joints, Air and Fuel Filters, Rear Fuel Tank, CPS, MAP, Cleaned EBP Tube and Sensor Replaced FPR Screen New 3" Downpipe and 4" Exhaust. Shimmed FPR Modified Air Box, Trans Temp Gauge, Boost Gauge, 8 New Glow Plugs. Not Sure What Else Yet...Any Ideas???
2004 Jayco Jayflight 26.5 5th Wheel (Truck pulls it like its not even there)
Acetcruiser is offline
post #15 of 100 (permalink) Old 11-08-2005, 10:14 PM
199K and still cruising. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed. CD Changer
Velvet rides installed. Joe Servo IDM mod was installed. Replaced with Swamps HV/HF IDM! Rear air lift springs. 4" exhaust installed all the back from DP and bye bye Kitty.
Sparkydm is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
1990 f250 idi
