I am installing an E350 7.3 in my 97 F350. E350 was supposed to be a 97 also. Although, on the Eseries the bowl is molded to the hpop reservoir so I swapped them. I’m doing Efuel, no need for bowl. Should I keep the screened gasket or go to what I had originally which was without it? Thanks a lot.
IIRC, you CAN NOT install the screened gasket in a reservoir that didn't originally have it.
'96 through EARLY '99 used the no-screen seal. LATE '99 through '03 used the one WITH the screen.
There is a slight design difference in the reservoir, and you WILL damage it if you try to install the screened seal.
From "Swamp's" website:
COVER GASKET WITH SCREEN:
For use in Late 1999 – 2003 7.3L Powerstroke engines to seal the HPOP reservoir to the front cover. For use in Engine Serial Number 1039780 to end of production (7.3L/t444e). This gasket has the filter screen. Do not use on earlier models as severe damage will occur to your front cover.
~Al
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
