Improved master cyl for the OBS trucks ??? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 09-18-2006, 10:27 PM Thread Starter
Someone posted sometime ago that there was a better brake master cly for the OBS trucks I tried the search to no avail..Part # bore size any info would be helpful... Thanks Burle
97 F350 4X4 CREW CAB PSD 5SP,3.55 REAR ENDS,BANKS POWER PACK,TYMAR INTAKE,Tony Wildman CHIP,HX MOD
OIL BY PASS,3 GAGE PILLAR EGT,BOOST AND OIL PRESSURE,GLOW PLUG RELAY BYPASS,COOLANT FILTER,GUTTED EBPV,31/2 EXAUST NO MUFFLER NO CAT,203 THERMOSTAT,POWERSHOT 2000 PROPANE.
Burle
burle is offline
post #2 of 4 (permalink) Old 09-18-2006, 10:30 PM
Re: Improved master cyl for the OBS trucks ???
I'll try to look for it, it was a service tip put out by a part mfg suggesting to go to a larger bore size, maybe by Mighty? I think I printed it and put it in the archives..........
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #3 of 4 (permalink) Old 09-19-2006, 01:37 PM
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
late 96's and 97's have it. It is a 1 3/8 bore where the early ones were 1 1/8 bore
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
post #4 of 4 (permalink) Old 09-19-2006, 09:14 PM Thread Starter
Thanks to all for the come back .. I'll check out the 1 3/8 bore.. Thanks again Burle.
Burle
burle is offline
