Intermittent start problem. Strange one - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-29-2013, 06:37 PM Thread Starter
I have a 1997 F-250 with the 7.3 PS. I have an odd intermittent start problem that 2 shops can't figure out the cause. Sometimes the truck won't start and sometimes it will chug for a second or 2 and stop. After 2-3 attempts it will start and run fine. Sometimes it will start up fine. The problem occurs if hot or cold. I recently drove it 6 hours and it ran perfectly. The fuel filter, oil, oil filter, air filter, CPS, and fuel pump have been replaced.
Would really appreciate some ideas on where to look for a problem like that.
Later, Bill
wandering is offline
post #2 of 8 (permalink) Old 04-02-2013, 07:19 PM
Does it smoke after cranking failure then start?
If it does is it white smoke?
phasers is offline
post #3 of 8 (permalink) Old 04-03-2013, 12:12 PM
Have you ever replaced the hpop ??
1995 PSD F-350 4X4
97 motor installed.
DaveH. is offline
post #4 of 8 (permalink) Old 04-03-2013, 08:41 PM
wiring
Did they check the harness under the valve cover watched a video on this the other day and sounds like the same thing
97_Stroke is offline
post #5 of 8 (permalink) Old 04-03-2013, 08:48 PM
wiring
Check this page scroll down to the audio clip and see if this what you have
Does your 7.3L Power Stoke Diesel feel down on power? Does it make a funny noise when starting? AutoRepairInstructions.com
post #6 of 8 (permalink) Old 04-04-2013, 03:50 PM Thread Starter
Thanks for the responses and I've been out of town for a few days.
I didn't see any problems with any exhaust smoke, however this morning it took a long crank time to get it to start ( didn't happen before) and when it did, some white smoke came out and then some dark. The truck was plugged in and warm.
No, it hasn't been replaced.
No, the diesel shop didn't check the harness because they started the truck numerous times and it always fired right up. A regular shop saw the problem, but couldn't figure out the problem, but did mention the UVC.
The noise is similar but not identical. When it starts, the truck runs fine.
Later, Bill
post #7 of 8 (permalink) Old 04-08-2013, 07:15 PM
bukhntr's Avatar
Glow Plugs
Test your glow plugs. Sounds like you have a few that are bad or like was said earlier a bad harness.
Dave
2013 F250 CC FX4 SWB Lariat,3-13 Build date,3.31, 18's, Line-x, Air Lift Ultimate bags w/wireless compressor, Demco Hijacker, 64K miles
95 F250SC PSD, XLT, 4X4,5SP close ratio w/Redline D4 ATF, 4.10 LS, LUK SMF w/Southbend Con O clutch, DPP downpipe & test pipe w/HP Ceramic coating,Full A Pillar w/Western Diesel pyro,boost, tranny temp,TYMAR intake, CA regulator kit, #5 to #4 HX, Skymech's glow plug bypass, fuel tank fillerneck mods, Sparky's AIC, Isspro TTM, Rhino liner, Alcoa wheel covers, Air Lift Super Duty bags on rear, DIY 6.0 Intercooler w/banks twin-ram inlet & compressor outlet, 283K miles
bukhntr is offline
post #8 of 8 (permalink) Old 04-08-2013, 08:21 PM Thread Starter
The truck will exhibit the same start problems when warm, so I'm told it isn't the glow plugs. Since the truck will run perfectly after it starts I'm not sure about the UVC. With the truck running you can wiggle the UVC connectors and it still runs fine. I've taken it over some really rough roads the last few days without any run problems. I'm trying to record the sound of the start up problem, but it has started fine the last 2 days...go figure.
Later, Bill
