IPR Votage ? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 03-30-2019, 06:53 PM Thread Starter
IPR Votage ?
97 Powerstroke Truck will not start Jumped 12 volts from the battery to the IPR plug , & the truck starts
On the red wire on the IPR plug i have 12.5 volts if i ground to the battery
If check the voltage from the red wire to the yellow wire on the IPR plug i get 9.8 volts
Any suggestion on whats wrong ???
roylll is offline
post #2 of 11 (permalink) Old 03-30-2019, 09:54 PM
klhansen's Avatar
My Photos: (180)
The IPR works with a constant 12V signal with the key in run on one wire, and a pulsed ground thru the PCM. So when you jumpered 12V to it, you forced the IPR fully closed, which cranks up your HP oil pressure sent to the injectors.
You may have an IPR that needs cleaning at the minimum or replacing.
Normally the first thing to try is to remove the plug from the ICP sensor (on the head), which makes the PCM use a standardized signal to the IPR rather than reacting to the ICP sensor signal. When you pull the plug off the ICP sensor, if you see oil in the connector, that's a sign that the ICP is bad.
Moving your post to the correct forum.
), AIS,
regulated return,
klhansen is offline
post #3 of 11 (permalink) Old 03-31-2019, 05:20 PM Thread Starter
It has a new HPOP & IPR , I removed the ICP plug still no start ???
roylll is offline
post #4 of 11 (permalink) Old 03-31-2019, 06:39 PM
klhansen's Avatar
My Photos: (180)
Do you have any way to check codes or monitor parameters. Sounds like you may not be getting the proper signals. Either that or your HPOP/IPR install has a problem.
Definitely get a scan tool on it. Monitor Battery Voltage, Engine RPM, ICP, IPR Duty Cycle, Fuel Injector Pulse Width. Good readings while cranking would be 8 V min, 100 RPM +, 500 psi min, 35% or lower IPR, 1-6 mS Injector pulse width.
), AIS,
regulated return,
klhansen is offline
post #5 of 11 (permalink) Old 04-01-2019, 09:55 PM
Have you got any mods on this engine? In particular, a crossover line?
Aside from the one time it started (when you had the IPR wired direct), has it run since you replaced the HPOP and IPR? If not, you may just have air in the high pressure oil system.
When you change those two parts, you gotta' do a very thorough air purge of the system - and even when you do it right, it very likely will still run rough for a while.
Kimber1911 is offline
post #6 of 11 (permalink) Old 04-02-2019, 10:12 AM Thread Starter
Have run it quite a bit with the IPR wired direct when it starts the volt gauge on the dash only reads 10 volts & runs rough on idle ( fine if you rev it a bit) when the voltage on the dash gauge get to 13 volts in about a minute it idles fine
I have not plugged the IPR back into the PCM since i got it fired , was told i need 12 volts across the red & yellow wire on the IPR plug which i do not i only get 9.8 volts with the key on & when it fires wired direct & running i get 11 volts on the IPR plug
roylll is offline
post #7 of 11 (permalink) Old 04-02-2019, 10:14 AM Thread Starter
No mods it is a factory stock truck
roylll is offline
post #8 of 11 (permalink) Old 04-02-2019, 11:42 PM
It sounds like you have air in the high-pressure system. Even if you purge the system properly, it still takes an hour or so of highway driving to finally get all the air moved through.
Is the HPOP a standard model for that truck and is it unmodified? Still has the check balls in it, etc?
post #9 of 11 (permalink) Old 04-04-2019, 10:59 AM Thread Starter
Yes the HPOP is standard for that truck , can I highway drive the truck for a hour with ti IPR wired direct ? I have run it for an hour @ 1,500/2,000 RPM with no load
roylll is offline
post #10 of 11 (permalink) Old 04-04-2019, 11:03 AM Thread Starter
Should the truck start with 9.8 volts checking @ the Red & yellow wire on the IPR plug & checking the red wire on the IPR to battery ground checking 12.5 volts
roylll is offline
post #11 of 11 (permalink) Old 04-04-2019, 02:29 PM
RT
RT's Avatar
You canít really check that voltage with a voltmeter. Itís a pulsed signal. Itís battery voltage but with a duty cycle. So, at 50% duty cycle, the voltage is being pulsed on half the time. Your voltmeter might give an erroneous reading, but it isnít accurate. You would need an oscilloscope to see whatís really going on.
RT is online now
Similar Threads
IPR how does it work? agomez Power Strokes 1994-1997 General 7 04-23-2016 11:47 PM
Possible IPR Problems STbasco 6.0L Power Stroke Engine and Drivetrain 13 04-21-2014 10:22 AM
Bad IPR? 73Diesel '99 & up 7.3L Power Stroke Engine and Drivetrain 8 01-16-2014 05:09 PM
High IPR Duty Cycle - Cold start smoke theory kurt Power Strokes 1994-1997 General 5 11-26-2013 11:48 PM
ICP / IPR Values (Truck vs Van) CanadianGTR '99 & up 7.3L Power Stroke Engine and Drivetrain 2 07-30-2009 09:18 PM
