leaf spring bushings - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-18-2006, 09:44 PM Thread Starter
jimzpsd's Avatar
I can't stand the binding and squiking of the poly bushings anymore and have decided to install oem rubber(I know, I know, it sounds backwards, but I've been dealing w/this annoying sound long enough. ..........Heres the question; the poly bushings will easily pull out of the leaf, but, is there a certain technique w/installing rubber,metal sleeved ones myself, or am I better off pulling the leafs out and letting a spring shop do it? Thanks
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's (sold it, has 328k miles)
2017 F-350 XLT, 4wd, CC, LB
jimzpsd is offline
post #2 of 6 (permalink) Old 09-18-2006, 10:08 PM
Re: leaf spring bushings
Take it to a spring shop. Rubbers are almost impossible to install by hand. Plus, if you use grease on the rubber it will greatly speed up the rubber deterioration.
KinkadeIN is offline
post #3 of 6 (permalink) Old 09-19-2006, 12:23 AM
get a couple of the tiny steel wedges use for splitting from a tile or rock supplier, tap them between the spring and eye loop until you can slide the steel/rubber in. I got my old ones out by hand this way, and you can do one at a time and not end up with the whole front end apart.
95 250 SC 4x4 auto 4:10 28,000 long cooler shimmed guages pipe WD chip, manual hubs, camper, 22' 5'er horse trailer
Rick Thielmann is offline
post #4 of 6 (permalink) Old 09-19-2006, 10:56 AM
I just went through all that with my poly bushings and found out the drivers side ball joints were shot...It's amazing how much noise they were putting out.
June 1996 F250HD XLT/SC, LWB, 4x4, 4:10LS, E4OD, White outside, Gray inside, Camper/Tow pack, Factory Aluminum wheels, Factory rear slider, decal free.
Factory AIC, Aux dash switches, Full add-a-leaf, Mile Marker SS Hubs, Upgraded E4OD Tranny, Tymar intake and HPX crossover line, BD downpipe, Exhaust brake, 203* stat, BriteBox, California Regulator mod, Truck Interiors Winterfront, Ported bug guard, Energy Suspension bushings rolling on 265x75 Bridgestone Revo's.
KD7UBW - PHAR (Public Health Amateur Radio)
2008.5 Mazda 3s Touring 5 door in Copper Red Mica w/indash 6 disk Cd changer/MP3 and moonroof: The Wifes
Rookie is offline
post #5 of 6 (permalink) Old 09-19-2006, 11:20 AM
Spray lithium grease on the inside of the leaf spring eye and set the new bushing in. Put a block of wood on top of the new bushing and pound away with a hammer till its in. You'll need to removed the springs from the truck of course. I've done this about 10 times in the past it works
RedPenguin is offline
post #6 of 6 (permalink) Old 09-19-2006, 08:05 PM Thread Starter
jimzpsd's Avatar
[/ QUOTE ]..................Very clever idea, I'm willing to try anything once. Thanks [img]/ubbthreads/images/graemlins/wink.gif[/img]
jimzpsd is offline
