MAP sensor Pig Tail wiring ? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By madpogue
post #1 of 11 (permalink) Old 01-06-2016, 07:39 PM Thread Starter
Aussie Bob's Avatar
Wink MAP sensor Pig Tail wiring ?
Hey guys,
I have a new standard brand pigtail for a MAP sensor for my 1997 power stroke. My problem is I need help with please is the wires are different colours from factory. My power stroke never came with a MAP sensor plug. The MAP sensor plug was removed to the inner lugs to run , I suspect a non compatible map sensor. I will test the frequency of the old MAP before I remove it. The new pigtail does not even fit in the old MAP socket.
This is the new pigtail, it has black with white trace on the left, blue with green trace in centre and orange with white trace on the right as pictured. The factory wires are green with black trace ( signal to pcm ) in the centre I think, Brown with a white trace for 5 volts+ and grey with a red trace for ground. Would anyone please know which colours go were ?
Bob
Aussie Bob is offline
post #2 of 11 (permalink) Old 01-07-2016, 09:33 AM
Patrick Feeley's Avatar
My Photos: (19)
See if the attached picture from my PCED helps. Cheers!
Name:	97 MAP Connector Wiring.jpg
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is online now
post #3 of 11 (permalink) Old 01-07-2016, 05:58 PM Thread Starter
Aussie Bob's Avatar
Excellent Patrick, thanks mate, your worth a million.
Bob
1997 F250 4x4 right hand drive conversion,automatic Power Stroke 3 inch lift, custom stacks, 33 inch tyres, TV DVD NAV, Three piece rear window, air compressor system ( air bags, air horns), custom tow bar, custom seats 8 way electric, after market electric windows winders , after market remote central locking , do you think I like this truck ? Bobs been busy
post #4 of 11 (permalink) Old 01-07-2016, 08:30 PM
^^^^ Is that in AUD or USD?.....
Aussie Bob likes this.
madpogue is offline
post #5 of 11 (permalink) Old 01-08-2016, 08:27 PM
Steve83's Avatar
Before you start cutting these wires, how about posting pics of the current sensor? I have to wonder if you're looking at the right thing, and it would suck if you cut the wrong thing off, spliced a MAP in its place, and then fried the PCM.
Steve83 is offline
post #6 of 11 (permalink) Old 01-09-2016, 11:28 PM Thread Starter
Aussie Bob's Avatar
I think this MAP sensor is not the wright one, anyhow it is producing a fault code and not producing a frequency.
Bob
post #7 of 11 (permalink) Old 01-10-2016, 01:19 AM
My Photos: (19)
Definitely the wrong MAP! Ours is larger than that if I recall correctly. Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #8 of 11 (permalink) Old 01-10-2016, 07:28 PM
blageurt's Avatar
My Photos: (9)
You have the wrong MAP.... ours are analog....I believe you have the Digital one....not compatible....
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
blageurt is offline
post #9 of 11 (permalink) Old 01-10-2016, 07:34 PM
blageurt's Avatar
My Photos: (9)
Ok ........these guys have the correct one.... Or any FORD dealer......Ford MAP sensor 7.3 Power Stroke DI Turbo Diesel '94-'97
As far as the Pigtail goes they are less than $10....Good Luck
blageurt is offline
post #10 of 11 (permalink) Old 01-10-2016, 10:11 PM
My Photos: (19)
Ours are the ones that output a variable frequency (which the Ford PCED refers to as digital). The ones that produce a variable analog voltage are accordingly called analog, are used on the 99 (and up I guess). Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #11 of 11 (permalink) Old 01-11-2016, 05:28 PM Thread Starter
Aussie Bob's Avatar
Thanks guys, I have one on order from eBay, I will let you know how it goes.
Bob
