Miss - No Power - Major Vibration - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 05-16-2019, 08:16 AM Thread Starter
Audiowriter's Avatar
ANYONE? Miss - No Power - Major Vibration ANYONE?
In December of 2018 I had an original injector go out. It is stock and has 450,000 miles on it.
I had all 8 injectors replaced with rebuilt ones. (plus glow plugs, under valve cover gaskets, GPR, and had the oil cooler rebuilt because of a leak.)
The truck ran fine until the TRS transmission range sensor went bad – replaced it and truck ran fine until a few months ago. The CEL would randomly come on – until I shut it off – and restarted – and CEL stayed off for several runs – then came back on – and repeat above.
Then one day I drove 100 miles – shut it off for 30 minutes – and it would not start – (tach needle moved) It was almost 2 quarts low on oil and a little low on antifreeze. Checked both - - and no coolant in oil – and no oil in coolant… (added oil & antifreeze)
After letting it sit for an hour – it fired right up. On the way home the CEL came on and a “SERIOUS” vibration started – but only when accelerating.
(I thought U-joint or etc…)
Took it to shop last week and found out that 1 of the rebuilt injectors on passenger side had a bad oil o-ring – (when the motor was cold it would start and run until shut off – then – when still warm – no start until it cooled off.) (Found coolant leak = fixed - and they rebuilt oil cooler... again... because it was leaking again = no charge...)
They found 2 bad injectors on passenger side and another injector bad on drivers side – changed 3 injectors total. (out of warranty. #*#&…) they also changed all 8 of the cups.
However – even with all 8 injectors passing contribution test at the shop –
BTW – it has a new fuel pump. Fuel pressure is good.
As of right now – it idles with a slight “miss” but it’s more like a partially plugged injector – and the “SERIOUS” vibration is apparently coming from the motor and is still there when accelerating and motor has absolutely no power – acts like missing – but more like “slightly out of time” IDM signals to the injectors ????
Guys at shop say possibly a bad compression ring / bent rod – or push rod / valve / etc.??? They are not sure?????
They don’t have a way to test compression.
Would a bad IDM cause this? Or bad CPS? Or a clogged EBP tube and sensor – I believe the tube and sensor have nothing to do with the EBPV – my EBPV is disabled – but I have never cleaned / replaced the EBP tube or sensor…
Below is a video of what it is doing now. (Watch the entire video - at the end it puffs smoke at high RPM???)
2 each - Stock - 97 F-350 7.3 PS 1 ton Duallys - RWD - AT
Audiowriter is offline
post #2 of 21 (permalink) Old 06-08-2019, 05:16 PM Thread Starter
Update…
I changed the CPS (old one was Oriley Auto – worked for several years – I know – I know – OEM… the new one is also oriley’s… I know, I know…) But….
It runs better with the new Oriley CPS – but still has miss and some vibration…
BUT – it is better than before??????
The ICP was replaced a few months ago (also Oriley… I know, I know – but now there is OIL in the plug connector – again…
BUT – I unplugged the ICP and started the truck – jerky idle – straightened out – but when I put it in gear it died instantly…
I plugged the ICP back in - and it will idle and take throttle – in gear – with brakes applied – but still has the “miss”.
Cant get the EBP tube to unscrew from the exhaust manifold to check / clean / or replace it – soaking it with WD40 and ETC. until I can get the threaded end to “spin” on the tube…)
Re cleaned the FPR screen – a little dirty – but not much change after cleaning…
Fuel pressure at idle with a tire pressure gage = 30 PSI.
Below are a couple of pics of the hood and fire wall with “soot / oil – where there wasn’t any before this issue…
When the issue started – I noticed the “exhaust / or – oil” on the hood and firewall near the turbo.
Maybe a plugged catalytic converter is causing some back pressure at the turbo???
Took off the turbo hoses and only saw a few drops of oil on the blades…
But when revving up the motor – in neutral – like the video shows - it sounds like there is “back pressure” at the turbo???
I just can’t believe that a new CPS would make the difference it did with a little better power and less vibration - if it is a mechanical issue (rings / rod / valve / etc.)
Or – maybe – the other 7 cylinders “came alive” better???
I know, I know – I need a compression check………………………….
Could the IDM or the Computer possibly be the culprit?
post #3 of 21 (permalink) Old 06-10-2019, 06:26 PM
Texkenusmc's Avatar
I had a similar issue and it was fuel pressure regulator. The spring got weak so I replaced it and fuel pump because it was also original with over 300,000 miles on it.
Texkenusmc is offline
post #4 of 21 (permalink) Old 06-11-2019, 04:20 AM Thread Starter
Texkenusmc -
Are you talking about the FPR (Fuel Pressure Regulator) at the fuel bowl with the spring -
(Like this --- ---
or -
the IPR (Injection Pressure Regulator) on the back of the HPOP -
(Like this --- ---
I'm guessing you are referring to the FPR at the filter housing that some guys modify with a BB...?????
The side of my fuel bowl looks a little different than the one in the video - I'll look at it again and take a picture of mine...
Thanx!
post #5 of 21 (permalink) Old 06-12-2019, 06:53 AM Thread Starter
UPDATE...
I did the "BB" mod on my FPR on the filter bowl = No Difference.
I swapped the IDM with my other truck = No Difference.
I have a new CPS (black with purple O-Ring) on order and a new Motorcraft ICP from Diesel O-Rings.
I don't believe I have a compression problem (valve / ring / push rod) - unless its a bent piston rod because I
placed the oil filler cap upside down over filler hole - revved the motor to 2500 RPM - cap did not move.
The tin nut on my IPR is tight - and from what I understand - usually when the IPR is bad - the motor won't fire or run at all - or does major hiccupping / etc.
Today I'll try unplugging each UVCH - 1 at a time and see if I can find out if it is a particular cylinder "missing".
Mine starts fairly good - and runs - has a "miss" and no power / and the vibration from the "miss".
BTW -
I just remembered that my son gave me a SCT Flash "tuner / scanner" a while back....
I'll hook it up today and see what I can find out with the minimal diagnostics it has to offer...
post #6 of 21 (permalink) Old 06-15-2019, 10:12 AM Thread Starter
UPDATE-
After unplugging the UVC harnesses - 1 at a time - I am certain the problem is on the passenger bank - one of the back 2 cylinders - I believe it is the second to the back (#5)
I ordered and installed Motorcraft (OEM) - CPS and ICP.
The miss is much better - the vibration is minimal. I now think this motor has had this issue for some time as it now runs much closer to what it had felt like for the past 80,000 miles or so - before this latest major issue.
I need to do a compression check - but first I'm going to OHM the injector wires from the IDM harness pins to the injectors and see if possibly the entire issue might be a bad wire in the harness. If it passes the OHM test - then I'll do a compression test.
post #7 of 21 (permalink) Old 06-16-2019, 07:05 AM Thread Starter
UPDATE-
The 8 GP's and both UVCG were changed 18 months ago when the 8 injectors were replaced.
Rechecked Fuel Pressure with 50 psi tire gauge at idle - got it to seal - buried the gauge - so I must have at least 60 PSI fuel pressure at idle.
However -
I checked the resistance from the IDM connector to all 8 cylinders.
All good -except for #7 - no resistance. (continuity is good from IDM connector - to - motor harness plug... must be somewhere from UVCG to injector)
Been storming here - I started removing the VC - but got rained out.
I'll try to find out if its the UVCG connector / or the harness inside / or the injector itself - so I know what's going on and what to order...
post #8 of 21 (permalink) Old 06-16-2019, 10:01 AM
Patrick Feeley's Avatar
My Photos: (19)
Once you get under there, check the solenoid resistance as it could be just a bad solenoid. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3” DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #9 of 21 (permalink) Old 06-16-2019, 10:29 AM Thread Starter
10-4 Patrick
Gotta look up what the resistance should be for just the injector solenoid - ? same a the line? 2.8 - to - 3.6 ??
post #10 of 21 (permalink) Old 06-16-2019, 11:01 AM Thread Starter
Just read that if an injector is "mechanically" bad - there will be NO CEL light-
But if it is an electrical problem with the injector - the CEL will light - (and possibly the IDM will shut down that bank...?)
Is this true?
I do not have a CEL - or any codes - - - is the injector incurring a mechanical (or o-ring) failure???
Because when I unplug the rear passenger (cylinders #5 & #7) there is very little difference in idle - but all of the other 3 make a noticeable difference
Well 1 code - P1111 - but it won't clear...
post #11 of 21 (permalink) Old 06-16-2019, 05:01 PM Thread Starter
NEW UPDATE -
Got the passenger side VC off... (what do you guys use to remove the back bolt? - It was a ***** for me - I don't have a flex extension...^%$(*&^#[email protected])
Any way-
I think the shop might have FU&KED me because...
After I removed the passenger side VC - I saw that the GP wire on #7 insulation was "scraped back" in 2 places & it gave a + continuity for a short to the oil that would "accumulate / pass by" it ...)
Then I OHMED the UVCH at the outer VC connection - on injector #7 - and NO RESISTANCE...
But the inner harness shows good continuity between the Outer UVCH plug - and the injector plug.....
Then I took off the solenoid - and there was a layer of oil between the solenoid - and - the injector actuator...
That has to be the "short" in the injector function / OHM reading...............
So... Either the "rebuilt" injector had a bad seal at the solenoid - or...................
They didn't even change that injector ------ a year and a half ago... and it's an original??????
The solenoids on cylinders 1, 3, and 5 have YELLOW solenoid covers with a AA marked on them...
BUT - the #7 solenoid Injector is a dark Brown / Black color and looks different - with a A00 #
What color are the original FORD injector Solenoids??????????????
Either way - the shop will say " the injector was bad when it came to us".......
And I could ask if they did an OHM check - after starting it - and it ran like **** - but they simply told me that "it didn't have any power".......
The dumb ass - money hungry - FUC$TARDS.....
Either...
I (they) got a badly sealed solenoid - or - they never changed it in the first place 18 months ago..............................
I MO B GETTIN EVEN with someone..........
I'll contact Rosewood and see if they can hook me up with an injector.......
Any thoughts or comments are greatly appreciated - from you experienced guys here on these forums!!!!!!!!!
AudioWriter....
post #12 of 21 (permalink) Old 06-16-2019, 08:24 PM
My Photos: (19)
If you ohm the solenoid directly at it's connection port, you should get around 3 ohms. Similarly if you connect the UVCH to it and ohm it at either the UVCH connector to the VC or at the VC with the UVCH connected, you should get the same. You would be measuring from the center pin to the appropriate immediately adjacent inner pin. The outermost pins are for the glowplugs and you should not get any continuity with the immediate adjacent inner pin. Cheers!
, 3” DP, Bilsteins,
, Gutted EBPV
post #13 of 21 (permalink) Old 06-17-2019, 04:18 AM Thread Starter
I tried that and it had no reading - until I took it apart - wiped the oil off - and with the solenoid off = then and only then did it read 3.3 ohms.
post #14 of 21 (permalink) Old 06-17-2019, 11:28 AM
My Photos: (19)
Wouldn't hurt to try a new solenoid! Cheers!
, 3” DP, Bilsteins,
, Gutted EBPV
post #15 of 21 (permalink) Old 06-18-2019, 04:25 AM Thread Starter
I will do a compression check -and if all is good...
Then, as soon as I get a solenoid (and a new UVCG) in from order - I'll see if a new solenoid gets an ohm reading attached to the injector and it runs better -
If all is good I'll go for putting the VC back on.
(Unless I need to order an injector.)
I will call Rosewood and see what they suggest. It looks and seems like the injectors on 1, 3, and 5 are good - but I know it is better to get a matching set.
Similar Threads
2002-2007 Ford F250 Super Duty Truck Power Heated Signal & Clearance Light Textured Black Dual Arm Power - Folding 1AAuto.com 1A Auto Parts 2 01-15-2016 08:43 AM
Miss, No Power blue_streak 6.0L Power Stroke Engine and Drivetrain 11 09-05-2014 09:11 AM
95 Low Power / Miss interceptor304 Power Strokes 1994-1997 General 2 04-07-2009 10:23 PM
Low power w/ Miss Blitzkrieg '99 & up 7.3L Power Stroke Engine and Drivetrain 0 11-13-2005 05:11 PM
Bully Dog Power Pup (Awesome)!!! WhonosWho Upgrades and Aftermarket - 6.0L Engine 12 02-20-2005 08:53 PM
