More brake problems - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-09-2009, 09:13 PM Thread Starter
More brake problems
On my 97 F350 my brake pedal is very hadr to push down and does not return once applied. Under throttle the pedal is slowly pulled to the floor. I recently replaced my vacuum pump because it went bad now I am having this problem.
druggles is offline
post #2 of 9 (permalink) Old 02-09-2009, 10:58 PM
blageurt's Avatar
My Photos: (9)
Sounds like you have serious Master cyllinder / Booster problems. Unplug the booster and see what happens. If the brakes work but are hard it is the booster. Other than that I would replace the Master ( assuming all is bled correctly and you have no obvious leaks and the fluid is good )
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
blageurt is offline
post #3 of 9 (permalink) Old 02-09-2009, 11:03 PM Thread Starter
I pulled the vacuum line from the booster so i could get a load of wood a couple days ago and the pedal quit going to the floor. But as expected the brakes were very weak. I replaced the booster 4 years ago but have only driven the truck 5,000 miles since.
druggles is offline
post #4 of 9 (permalink) Old 02-09-2009, 11:13 PM
okney1lz's Avatar
It could....
It could be bad again. Stranger things have happened. Booster is also my guess for the symptoms you're describing.
97 F-350 XLT 4x4 in pieces all over my garage floor. Imagine that!
okney1lz is offline
post #5 of 9 (permalink) Old 02-09-2009, 11:35 PM Thread Starter
It seems like since I quit driving this truck all the time parts that I had recently replaced on the brake system keep going bad. The last vacuum pump had less than 10,000 miles on it.
druggles is offline
post #6 of 9 (permalink) Old 02-10-2009, 09:18 AM
If I recall the rules correctly:
- hard pedal = bad vacuum pump or vacuum leak
- soft pedal = air in lines, bad fluid, leak in brake lines, bad master cylinder
I've replaced the vac pump several (3,4,5 times?) in the 101k miles I've owned the truck. Would love to go to hydroboost brakes but no room in the budget right now...
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter x3, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, newer black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, new fast-spool turbo 7/11, 317k miles on 18 Oct '14; probably won't run forever but neither will I
JoshR is offline
post #7 of 9 (permalink) Old 02-10-2009, 11:05 AM
Did you put a vacuum gage on it to see how much you have IIRC you need at least 10.5 inches of vacuum for booster to operate. Just my .02
97 F250 Ext Cab E4OD,245K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
post #8 of 9 (permalink) Old 02-10-2009, 04:48 PM
blageurt's Avatar
My Photos: (9)
Maybe you bought Chinese made parts. I used to, Not anymore . Now , I only buy Made in USA or Canada , OR Rebuilt locally . . . No Mexico / Brazil /China etc. It costs a bit more but they last longer.
blageurt is offline
post #9 of 9 (permalink) Old 02-11-2009, 01:03 AM
Patrick Feeley's Avatar
My Photos: (19)
I vote for Booster, especially if the pedal gets "pulled" to the floor. Get the zer-loss booster for a replacement.
Brake Booster, Zero-Loss (94-97)
(Ford) F5TZ-2005-CA (not a service replacement; it must be ordered by the part number, not vehicle application … from TSB 96-25-19, but TSB number not verified)
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
