Multifunction switch update. - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 07-03-2017, 10:56 AM Thread Starter
Audiowriter's Avatar
Well, Rock Auto had sold the last over 8500 lb gvw mfs. So, I had them notify me when they had one on stock.
In the meantime, my local Oriley's showed on line that they had one in stock.
I called and they confirmed it.
I went there - and they did NOT have one in stock and it was a special order item - had to pay up front - but when they tried to order it from Dorman - Dorman's web server kept disconnecting.
When I returned home - Rock Auto notified me that they now had one in stock - I ordered it - it came the other day.
It is indeed the correct one (NOT short model for Bronco's and such
When I took the current one off, what I found out was causing the cancel to not work was that the "+" piece on the column had come out of the square receiver on the switch and was not making the cancel lever "trip" the connector.
The old mfs is not broken at all - Months ago when I had accidentally "bumped" the switch when the steering wheel was at the "cancel" position - I simply had caused the interlocking + and square interlock to "dislodge" and render the cancel useless - but nothing had actually broken.
Maybe this will be helpful to someone in the future - if their turn signal cancel stops working. You may not need a new mfs - you may simply have to remove the current one - and re-align the + on the column with the square receiver on the switch. Just make sure the steering wheel is NOT at the cancel position (make sure the wheels are lined straight ahead) when installing (or re-installing) a mfs.
I am much happier with the over 8500 lb vehicle (longer) model as compared to the shorter one I have been using for a very long time!
2 each - Stock - 97 F-350 7.3 PS 1 ton Duallys - RWD - AT
Audiowriter is offline
post #2 of 7 (permalink) Old 07-03-2017, 11:27 AM
This ^^^^ is one reason I always center the steering when I park on level ground. Maybe they designed it with that separate piece that could be dislocated/relocated intentionally. I think with the older design, it would've just broken the canceller. Cancellers are broken off on my '85, but I think that's just from age.
There's a difference between models? How is the "short model" different? I thought we all used the same column. Oh, I think there might be a difference whether it's a tilt or no-tilt column, but that would have nothing to do with model, GVWR, etc.
madpogue is offline
post #3 of 7 (permalink) Old 07-03-2017, 12:31 PM
Steve83's Avatar
Go to Official Ford Parts Site , enter your VIN, point to "Electrical, Lighting, & Body", and click "Switches". Change results per page to 75, find "Turn Signal Switch", and post what you find.
For a '93 Bronco, the options are SW5591 with red hazard button (original), and SW2485 with black.
For a '95 F150, only the black is recommended.
For '96 Bronco, both.
For a '95 F350 CC dually PSTD, only the black.
BTW
If you log into that site, you can save VINs and label them so you don't have to re-enter them each time to look up PNs. I have a bunch saved so I can compare things like this. But another way to do it is to click the "Buyer's Guide" tab, enter the PN, and look at the list of vehicles using that part. For SW2485, it's:
Years . . . Make Model Engine Qty per Vehicle
1992-1996 Ford Bronco All Engines 1
1992-1997 Ford F Super Duty All Engines 1
1992-1996 Ford F-150 All Engines 1
1992-1997 Ford F-250 All Engines 1
1992-1997 Ford F-350 All Engines 1
So as you see, trucks over 8500 use the same MFS as those under.
Steve83 is offline
post #4 of 7 (permalink) Old 07-04-2017, 09:04 AM Thread Starter
What vehicles are the shorter MFS for then?
post #5 of 7 (permalink) Old 07-04-2017, 11:33 AM
Do you have part numbers for the two?
madpogue is offline
post #6 of 7 (permalink) Old 07-04-2017, 12:03 PM
Steve83's Avatar
Originally Posted by Steve83 View Post
Go to Official Ford Parts Site , ...click the "Buyer's Guide" tab, enter the PN, and look at the list of vehicles using that part.
But I've never seen a "shorter" MFS lever. They're all designed for the same-diameter steering wheel on the same steering column, so they're all about the same length. Some bend up; some bend down; some are straight; some have chrome; some have extra terminals for cornering lights; some have an extra dial for a rear wiper (SUVs & hatchbacks)... But they're all pretty much interchangeable on this steering column.
Steve83 is offline
post #7 of 7 (permalink) Old 07-07-2017, 08:47 AM Thread Starter
I guess the different angle of the stem on the one I previously had installed makes it look and seem shorter because when installed - the end where the wiper delay dial is so far forward of the steering wheel. I didn't put them side by side to compare - but when looking at them near each other - they give the illusion of having different lengths.
