Need Help Draining Tank - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 01-11-2019, 06:59 PM Thread Starter
The previous owner allowed water into my front tank on 97 powerstroke F250, was wondering what the easiest way to go about draining the tank would be? All help is appreciated, thanks in advance.
Tanner Crawford is offline
post #2 of 4 (permalink) Old 01-11-2019, 07:12 PM
bugman's Avatar
My Photos: (12)
How much fuel do you have in it?
If it is full get 5 5 gallon jugs and a siphon hose.
Or rig up a diesel rated electric fuel pump and let it pump it out.
Then you can always just drop the tank and turn it upside down with the gauge sending unit pulled out.
bugman is offline
post #3 of 4 (permalink) Old 01-11-2019, 07:18 PM
Steve83's Avatar
Disconnect the fuel line, run it into a catch-can, and either connect a little 12V fuel pump, or use a siphon.
Steve83 is offline
post #4 of 4 (permalink) Old 01-14-2019, 10:41 AM
If it was me, Iíd just drop it and replace it. Chances are itís not in great shape anyway. Both my tanks went bad and replacement wasnít a big deal. Aftermarket are pretty affordable.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is online now
