No Start 7.3 psd - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-10-2019, 10:57 PM Thread Starter
No Start 7.3 psd
I have a 94 7.3 psd an I have a no start issue. I've checked everything from the hpop oil level, I've changed fuel filter, barely 200 miles on it. So I gave it a small shot of either an it fired right up. An it stays running. No smoke on start up at all. All glow plugs are working an relay is working. Cleaned the scream on the fuel regulator on the fuel bowl. Has fuel in fuel bowl no oily fuel. So idk if it's the lift pump getting weak or the check valve bleeding off pressure. It's always fired right up until last week where alot of hard starts. Any advice is greatly appreciated
Obs7.3-71-FORD is offline
post #2 of 6 (permalink) Old 04-11-2019, 10:17 AM
Patrick Feeley's Avatar
My Photos: (19)
How are you determining the GPR and plugs are working? What's the fuel pressure when cranking (minimum spec is 25 psi and minimum crank speed of 100 rpm)? White smoke when cranking? Tach moving while cranking? How's the oil level? CEL illuminated? Any oil in the Injection Control Pressure (ICP) sensor connection? Have you tried plugging the block heater in for about 3 hours prior to a cold start? Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is online now
post #3 of 6 (permalink) Old 05-12-2019, 01:39 AM
can You please let me know if you solved your problem and how?
Dallas97PSD is offline
post #4 of 6 (permalink) Old 05-12-2019, 11:39 PM Thread Starter
New gpr, new gps, valve cover gaskets, ipr, idm, icp. Put s starter in it an hasn't done it since then.
post #5 of 6 (permalink) Old 06-10-2019, 04:18 AM
Had same problems changed out fuel pump cause wasn't getting enough fuel pressure and had to change out HPOP and lcp valve. Burnt up HPOP due to not getting enough fuel . Running super right now
rayroof10 is offline
post #6 of 6 (permalink) Old 06-24-2019, 09:39 PM
I had to replace my fuel pump and hpop and the icr valve. Running like a champ now.
Similar Threads
93 7.3 turbo, hard start up, this one is different....please read 93FordDieselDually 7.3L IDI Diesels (Not Power Strokes) 9 07-24-2012 12:04 AM
6.9 7.3 Identification info IDIABUSE 7.3L IDI Diesels (Not Power Strokes) 6 04-10-2011 12:34 AM
1989 7.3 IDI dead and won't start again DuallyCrew 7.3L IDI Diesels (Not Power Strokes) 15 01-07-2009 08:58 PM
6.9 and 7.3 parts interchangeable? RajinCajun 7.3L IDI Diesels (Not Power Strokes) 15 03-26-2006 11:46 PM
no start PSD 7.3 builderben '99 & up 7.3L Power Stroke Engine and Drivetrain 10 01-22-2006 03:43 PM
