No throttle response check engine light - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-20-2019, 09:02 PM Thread Starter
Hello, hoping someone can help. I have a 94.5 that I have owned for many years. It has a TS6 chip and stage 1 absolute diesel injectors. Both have been flawless for years. Recently the check engine light will come on, it starts running rough, and it will just barely rev when pushing the accelerator. This happens randomly. Usually it will start back, but not always. I replaced the cps but that didnít help. Canít pull any codes either. Iím at a loss on where to start.
tx4wheeler71 is offline
post #2 of 2 (permalink) Old 08-20-2019, 09:48 PM
Patrick Feeley's Avatar
My Photos: (19)
I would physically remove the chip and see if the problem stays the same or not. Also, check all you valvecover harness connectors for evidence of melting or burning. Remove the oil cap and sniff to see if it smells like burned wiring insulation. Check for oil in the ICP connection. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3Ē DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
