oil in coolant bottle - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-13-2005, 09:16 PM Thread Starter
changed the oil the other day checking all the fluides and found engine oil in the coolant res. i changed the oil cooler o-rings not sure if that took care of it any other suggustions ????????????
2000 F250 Crew Cab short bed 4in lift 35 in tires TS 6 position chip Kale Thompson custom tunes Hypermax H2E quick spool 66mm. Fullforce stage3with oil mod big oil stealth stage 2, X monitor ,BTS tyranny with 6.0 cooler Fass fuel system on,its way 255000 miles and still going.
rwb1996 is offline
post #2 of 7 (permalink) Old 04-13-2005, 10:38 PM
My Photos: (10)
Re: oil in coolant bottle
maybe flush ur coolin system out and keep an eye on it. if oil shows up again then start checkin things
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights, 1000cca batteries
************future mods*******************
intercooler, smaller turbo housing, window tinting
03 vw jetta tdi stock for now
traxmedic is offline
post #3 of 7 (permalink) Old 04-13-2005, 11:14 PM Thread Starter
what should i check then
rwb1996 is offline
post #4 of 7 (permalink) Old 04-13-2005, 11:24 PM
seandrisc's Avatar
might want to check injector o rings
97 f 250 4x4 auto,isspro guages,bd downpipe,bd autolock,michelin xps traction tires,b&w turnoverball,ts chip-Thanks Renegade SLAPS MEMBER
seandrisc is offline
post #5 of 7 (permalink) Old 04-14-2005, 12:32 AM
Ok dont panic yet, I had a simalar problem except I opened My coolant res and thick black sludge came out over the top. It is mostlikely your oil cooler. it is the most commen way to get oil in to the coolant, I put a whole new cooler in. injector oring although a posabilty ar less likely, You are more likley to get fuel in your coolant fron injector orings, so make sure it is oil we are talking about, a blown head gasket could also get oil in coolant but you will probably have a huge mess under the hood. after I changer my oil cooler I ran water and draind it , water and drained it, and so on it took me 2000-3000 miles to be running clear coolant again it is a big coolant sys so be patiant, you can also run water with some casscade dish washing soap through not too much to help clean out the coolant sys. so if you keep getting oil I would swith tha whole iol cooler out but give it time, my cooant is green and purty now !! good luck J
97 f-350 , CC,LB 4x4 e40d. kwick filter gutted cat, 10K, 1.10 turbo , 185K miles
wycowboy is offline
post #6 of 7 (permalink) Old 04-14-2005, 10:08 AM
It's probably left over oil from the cooler rings. Search the archives for Cascade dishwasher soap.
Seems that was the choice, I think because it's non foaming.
Dan
'01 F250 4x4 Crew Shorty, PM Rods, new PIS 160/30's, D66 compressor by Dieselsite/w 1.00 ex housing, EBPV delete, ITP Regulated fuel return, Ford AIS.
Dan V is offline
post #7 of 7 (permalink) Old 04-14-2005, 03:05 PM
[/ QUOTE ]Usally it is the O-rings in the Housing that are the culprit.But I have been Burned a couple times on The Cooler bundle itself having a cracked solder joint on a Tube Thus still leaking oil into the coolant after a Oring job.A factory Exchange Re-man cooler is Ones best bet unless you have the Core Bundle Pressure checked while your doing the Orings.If the problem persists after flushing out the system this usally is whats wrong.I wouldnt be concerned about Inj O-rings They have nothing to do with Oil in coolant.Cracked Inj cups will Put Fuel in coolant or vice versa.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
