Oil leak after wreck - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 09-19-2006, 11:03 AM Thread Starter
Posting this for a friend. He has a 97 350 cc manual tranny. He is leaking a lot of oil. This all started when a dear jumped out in front of him. Should have hit the thing but human instinct took over and he put the truck on its side. Everything fixed exept this leak. Can some guys chime in and give us the most common areas to look for a leak. He is losing at least a quart per week. Thanks for the help.
White 1996 F350 CCLB PSD 4x4. GEMTOP "Outfitter" fender flares, visor, side steps, 33's, WARN hubs, Tru-cool 4739(no bypass), Tymar Intake, 3x4 DP, 4 inch straight pipe exhaust, 3 pod "A" pillar (Boost, EGT's, Tranny) International Badges
nathansdq is offline
post #2 of 5 (permalink) Old 09-19-2006, 11:10 AM
brahamfireman's Avatar
Re: Oil leak after wreck
engine oil, trans oil, or is it fuel?????
there is no cooler for the trans and the cooler for the engine is on the motor, no hoses or anything, have to crawl underneither and find out where it is coming from.
Diesel Rod
Formerly Diesel Rod.
A
with 295K miles, 90 LED's and 5" stacks, among other things....
A
Reg cab with 210K miles, Needs to go away. PM me.
SHORT HOOD. The ongoing "project" it aint pretty but its got a
425 air to air Cat motor
.....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
post #3 of 5 (permalink) Old 09-19-2006, 11:16 AM Thread Starter
Sorry. Oil was not specific. It is engine oil.
post #4 of 5 (permalink) Old 09-19-2006, 11:21 AM
is it leaking on the ground or just disapearing????? check the coolant, might have a bad oil cooler. could have a cut O-ring on the injector and it is burning it off.
if its leaking on the ground could be a front/rear main, oil cooler, Valve cover gaskets, Dip stick on the side of the pan, could be the oil pan bolts.
I have come across oil leaks in all these places.
Diesel Rod
A
A
post #5 of 5 (permalink) Old 09-19-2006, 11:30 AM Thread Starter
Thank you sir. Exactly what I need.
