Parking Brake Indicator Light - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-19-2006, 03:38 AM Thread Starter
PSDfreak's Avatar
What turns the parking brake indicator light on? Mine sometimes does not come on when I set the parking brake...If I let it off and push the pedal in another time or two it will come on...Is there a switch under there that when the pedal starts to move it turns the light on? I looked but didn't see anything...
The problem is what I want to use my AIC sometimes I have to set the brake a couple of times before the light will come on. (Indicator light has to be on for the AIC to work).
Thanks,
Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #2 of 3 (permalink) Old 09-19-2006, 11:06 AM
brahamfireman's Avatar
Re: Parking Brake Indicator Light
Yes I just went out and looked on my '97.
at the top of the E-brake assembly there is a one wire switch, green with a red tracer, prolly wrapped in a black wire loom.
power is sent to the light on the dash, then to the switch on the assembly, when you push the pedal the switch grounds out on the pedal, thus turning on the light and your AIC. you either have a bad connection at the switch or the switch has a bad ground, you will find the switch if you pull the E-brake assembly off.
Diesel Rod
Formerly Diesel Rod.
A
with 295K miles, 90 LED's and 5" stacks, among other things....
A
Reg cab with 210K miles, Needs to go away. PM me.
SHORT HOOD. The ongoing "project" it aint pretty but its got a
425 air to air Cat motor
.....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
post #3 of 3 (permalink) Old 09-19-2006, 04:34 PM Thread Starter
PSDfreak's Avatar
Exactly what i was look for...thank you sir.. [img]/ubbthreads/images/graemlins/wink.gif[/img]
-Casey
PSDfreak is offline
