Part location - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-07-2009, 05:08 PM Thread Starter
Part location
Can somebody tell me where the the PCM and IDM is? and what is the breakout box?
Rick
1995 F350 PSD 4x4 C/C LB
Tymar style intake, gutted kitty, more goodies to come!
Transplant is offline
post #2 of 5 (permalink) Old 02-07-2009, 05:39 PM
klhansen's Avatar
My Photos: (180)
Your PCM is located by your left foot with the connector sticking thru the firewall (It's the longer skinny one). The IDM is mounted just just below the driver's side hood hinge.
A breakout box is a diagnostic tool that plugs in between the PCM and connector and lets you check the voltage signals with a multimeter or if only the harness side is connected, the continuity of the circuits. It "breaks out" the connections for you.
Also, an injector breakout box (actually a misnomer, should be called a cutout box) installs between the engine harness and the body harness and has switches to allow you to turn off injectors individually.
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 02-07-2009, 06:41 PM Thread Starter
Thamks kl.
Does the PCM come out through the engine compartment or the cab?
Rick
post #4 of 5 (permalink) Old 02-07-2009, 07:59 PM
4micaman's Avatar
The main body of the PCM is inside the cab. Only the connection port extends through the firewall. It's just below and to the left of your master cylinder/booster.
-Steve
'95 F-250 SC/LWB, 7.3L, E4OD, 4:11LS, 2WD
IDM Mod, HPX, DIY Intake
Rebuilt Fuel Canister 7/29/12 - 152k (Heater Removed, 4-40 screw, new IPR pigtail, WIF temp. disconnected)
4micaman is offline
post #5 of 5 (permalink) Old 02-07-2009, 08:26 PM
4micaman's Avatar
Sorry, I misread your question. The PCM comes out (removed) from inside the cab. The connector has a bolt that holds it in tight, then there are the mount under the dash.
-Steve
4micaman is offline
