Pedestal o-rings and.... - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-26-2017, 10:47 AM Thread Starter
Massive oil leak, looks like it's flowing down from pedestal... 330,000 miles on my 96 ... what else should i look for when i get in there to do orings?
Thanks,
Ken
1996 F350 2wd Dually Crew Cab...100% stock except fuel heater delete... 325000 miles so far
Dieselnn is offline
post #2 of 3 (permalink) Old 10-26-2017, 11:16 AM
edwester03's Avatar
The seals on the actuator can go bad too. Once you get it off take a good look at it and you'll see if the actuator is leaking. Just did mine a few months ago and it was just the o rings. Soak all those bolts for the turbo and exhaust before you go digging into it. Best of luck. Just be patient
Sent from my LG-H871 using Tapatalk
edwester03 is offline
post #3 of 3 (permalink) Old 10-27-2017, 12:07 AM
Clean it real good and recheck the leak a few times. I pulled my turbo and replaced O-rings only to find the turbo center housing had a crack that was leaking. Edwester03 has great advice spray all bolts and clamps with whatever panther piss you like several times before you do the job.
DENNY
DENNY is offline
