Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   Power Strokes 1994-1997 General (https://www.thedieselstop.com/forums/f28/)
-   -   Power steering pump or gearbox? (https://www.thedieselstop.com/forums/f28/power-steering-pump-gearbox-340874/)
sumter_f-250 05-06-2013 07:18 AM
Hey guys,
I return to the best forum once again in need of advice/help. For a while now, I have had some play in my steering wheel (almost 1/4 turn before steering responds). Where could this play come from? I can watch the linkage from the cab into the box to be moving and the steering tie rod won't move. But I don't know where I can adjust this play.....any advice would be great!
Patrick Feeley 05-06-2013 02:26 PM
There is a jam nut and screw on top of the steering gear box that can be adjusted, but you have to be careful not to tighten it too much. I would do a very little bit at a time to see if it helps. If the steering wheel doesn't return on its own, you've probably overdone it. Also, check the steering shaft to make sure there is not slop in it where the shaft sections come together. Cheers!
dieselsmokerdoug 05-06-2013 07:18 PM
also check the bolts for the steering box, i had to replace mine because they stretched . to check them get someone to wiggle the steering wheel back and forth and someone to look at the box to see if it wiggles against the frame.
Jcart 05-11-2013 11:11 AM
If the mid steering shaft (steering column to box) is loose replace with a borgeson mid shaft. I have a write up in my sig link, results are worth the effort there is also an interim fix too.
jrc
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
