Power steering pump or gearbox? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-06-2013, 07:18 AM Thread Starter
sumter_f-250's Avatar
Hey guys,
I return to the best forum once again in need of advice/help. For a while now, I have had some play in my steering wheel (almost 1/4 turn before steering responds). Where could this play come from? I can watch the linkage from the cab into the box to be moving and the steering tie rod won't move. But I don't know where I can adjust this play.....any advice would be great!
96' F-250 4X4 Supercab 7.3L stock on 37x12.50 goodyear wrangler mt military tires, 5 spd, 4" straight piped, 6" suspension lift, Dana 60 conversion, 4.10 gears, custom bumpers, 12000 lbs. Badlands winch
sumter_f-250 is offline
post #2 of 4 (permalink) Old 05-06-2013, 02:26 PM
Patrick Feeley's Avatar
My Photos: (19)
There is a jam nut and screw on top of the steering gear box that can be adjusted, but you have to be careful not to tighten it too much. I would do a very little bit at a time to see if it helps. If the steering wheel doesn't return on its own, you've probably overdone it. Also, check the steering shaft to make sure there is not slop in it where the shaft sections come together. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 05-06-2013, 07:18 PM
dieselsmokerdoug's Avatar
My Photos: (22)
also check the bolts for the steering box, i had to replace mine because they stretched . to check them get someone to wiggle the steering wheel back and forth and someone to look at the box to see if it wiggles against the frame.
1997 F250 HD XLT 4x4 ext cab long box mbrp 4"pipes with 6"tip& 3"downpipe, 410 rear gears, add a leaf on front , rebuilt trans e4od 12"x13"transcooler with a thermostatic fan , TOYO open country AT's 285x78x16 & opened up air box with a k&n filter. 2012 Salem Grand Villa 408reds with 3 slides
dieselsmokerdoug is offline
post #4 of 4 (permalink) Old 05-11-2013, 11:11 AM
Jcart's Avatar
If the mid steering shaft (steering column to box) is loose replace with a borgeson mid shaft. I have a write up in my sig link, results are worth the effort there is also an interim fix too.
jrc
97 XLT F250 CC ZF-5 (now
) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, 6.0 fan, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, 200 amp alternator, 1500 watt inverter.
Jcart is offline
