Power Steering Pump Removal - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 06-17-2006, 10:52 AM Thread Starter
DaveBey's Avatar
My Photos: (203)
In preparation for removing the power steering pump, I was reading the procedure in the shop manual and it mentions removing the power steering pump pulley and then the pump. It also mentions it may be necessary to remove the fan shroud to allow for proper installation and operation of the power steering pump pulley remover tool. Is this true? Just want to make sure I have the necessary tools available for the project.
REMOVAL AND INSTALLATION
Pulley, Power Steering Pump
Steering Pump, Power—5.0L, 5.8L, 7.5L, 7.3 Diesel
Cheers from Tulsa, OK! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4
-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●APCM
250,000 happy miles
DZLJIM 3:16
- Hold my beer and watch this.~~
DaveBey is offline
post #2 of 3 (permalink) Old 06-17-2006, 11:32 PM
Racer_X's Avatar
Re: Power Steering Pump Removal
I have the snap on puller and it fit without pulling the shroud. The mounting bolt(s) are behind the pulley. Can't remove them all with the pulley on. They just back up until they hit the pulley.
POWERFLOW BY RACER X - 1997 F-350 Twin Turbo charged 7.3 Power Stroke Diesel fueled with 473 cc's of diesel plus nitrous, equipped with a Custom
Racer X E4OD transmission making 800 r.w.h.p. on video! The first successfully Twin Turbo Charged 7.3 PSD!
Owned & sponsored by :
Racer_X is offline
post #3 of 3 (permalink) Old 06-18-2006, 01:40 PM
PSDfreak's Avatar
Exactly...You DO need to take the pulley off FIRST, otherwise the bolts will cannot back all the way out. The puller I have fits without pulling the shroud as well...I'll see if I can find a pic and post it.
Good Luck!
Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
