replacement door panels?? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-08-2009, 08:13 PM Thread Starter
JDrescher's Avatar
My door panels are starting to break apart and rattle. Were is a good place to get replacements. Thanks
-Jeff-
Home of the Tekonsha Brake controllers
96 F-350 PSD~4x4~Reg cab~SRW~E4OD~ 233,000~3.55~Dominator 66~E99 spyder with 7.3 SD intercooler~DP Tuner F5 stock,hi idle,60tow,60econ,80econ,120race,140,lope idle~BTS trans~BTS custom trans cooler setup~RDS Stage 1 injectors~Labonte Water-Meth kit~upgraded downpipe~4in straight exhuast~EBPV into exhuast brake~Tymar intake~Tymar HPX line~FPR mod~boost,trans and pyro guages
adrenalin HPOP and modded IDM are up next!!
89 F-250~4x4~Reg cab~7.3 IDI~ZF 5 speed~6 in stacks~155,000~(My beater)
JDrescher is offline
post #2 of 8 (permalink) Old 02-08-2009, 11:55 PM
X's 2
1996 F-350 psd crew drw, demuffed, fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! Stancor gpr (12/26/07) Coolant filter (11-1-2008) Relocated Block heater plug (1/01/2011) Tranni by JOHN WOOD (12-08-2009) Thanks JOHN more mods to come.
fordmedic is offline
post #3 of 8 (permalink) Old 02-09-2009, 11:00 AM
drwoodchopper's Avatar
LMC truck parts. 1980-1996 Ford Truck 1980-1996 Ford Bronco - LMC Truck Featured Products
1997 F350 CC4X4 RSK RIDING ON 35's 3:55's, 230K, DP tuner 6 pos chip! IDM mod, Pyro, Boost and Trans Autometers over mirror. Oil and Water temp in hand built "hump cubby" 4" straight pipe! . ZF5 Conversion 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline. WOP QSSB turbo e-fuel conversion and a custom CNG system, yea it gets like 32mpg's. 2011 6.7 F350CCSWB H&S Minni Maxx. My Youtube vid.
drwoodchopper is offline
post #4 of 8 (permalink) Old 02-09-2009, 11:36 PM
169stang's Avatar
My Photos: (5)
I really do not like the LMC website. I can never find what I'm looking for specific to a 97 F350 CC DRW.
1997 F350 7.3L CC DRW 2wd
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
169stang is offline
post #5 of 8 (permalink) Old 02-10-2009, 01:14 PM Thread Starter
JDrescher's Avatar
I checked the LMC website and called them and they dont offer replacment door panels for the 92-96 interior. I also checked all over ebay and cant find much there either
-Jeff-
post #6 of 8 (permalink) Old 02-10-2009, 01:23 PM
dealer does but be prepared....
/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
post #7 of 8 (permalink) Old 02-10-2009, 02:13 PM
I have never ordered from them but I am sure I had them in my last catalog. They all said 96' model year but should be the same. 97' is a different catalog as the F150's changed.
post #8 of 8 (permalink) Old 02-10-2009, 02:33 PM
Yall try car-parts.com. Used parts nationwide locations they usually have what you need at a reasonable price.
97 F250 Ext Cab E4OD,245K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
