replacement seat?? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-08-2009, 08:12 PM Thread Starter
JDrescher's Avatar
replacement seat??
My drivers seat is getting pretty worn so i was looking for a good place to get a whole replacement seat or just the foam cushion. Thanks
-Jeff-
Home of the Tekonsha Brake controllers
96 F-350 PSD~4x4~Reg cab~SRW~E4OD~ 233,000~3.55~Dominator 66~E99 spyder with 7.3 SD intercooler~DP Tuner F5 stock,hi idle,60tow,60econ,80econ,120race,140,lope idle~BTS trans~BTS custom trans cooler setup~RDS Stage 1 injectors~Labonte Water-Meth kit~upgraded downpipe~4in straight exhuast~EBPV into exhuast brake~Tymar intake~Tymar HPX line~FPR mod~boost,trans and pyro guages
adrenalin HPOP and modded IDM are up next!!
89 F-250~4x4~Reg cab~7.3 IDI~ZF 5 speed~6 in stacks~155,000~(My beater)
JDrescher is offline
post #2 of 3 (permalink) Old 02-09-2009, 03:44 AM
PSDfreak's Avatar
You can get a new seat foam piece at an unhostlery shop...other than that, check for local truck dismantlers, you can start with car-part.com
I know there is a place near me that I go to, they have maybe 100 or so good sets of front seats....Around 400 bucks there will get you a complete front seat set.
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 3 (permalink) Old 02-09-2009, 06:50 PM Thread Starter
JDrescher's Avatar
thanks ill check it out!!
-Jeff-
