Replacing power door lock actuator - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-19-2006, 01:40 PM Thread Starter
Hi gang,
I have a "97" F350 Power Stroke. The power door lock actuator on the passenger side has gone bad.
Can anyone tell me how to get the darn thing out of the door? Also, where is the least expensive place to purchase a replacement actuator.
Thanks,
Rick
Rickjw is offline
post #2 of 3 (permalink) Old 09-19-2006, 01:44 PM
Re: Replacing power door lock actuator
Edit:
Nevermind....sorry.
-Mike
2000 F350 7.3L PSD/4x4/6-Speed/Crew Cab/Long Box/
/100k miles
1995 F250 7.3L PSD/4x4/Automatic/Extended Cab/Long Box/4.10 LS Diff./
/250k miles
mykldn is offline
post #3 of 3 (permalink) Old 09-19-2006, 09:00 PM
BigBadLou's Avatar
My Photos: (14)
I bought the replacement actuator motor on eBay. With success. I did both rear doors (they went bad within a month of each other).
The motors are located at the very rear of the door, under the door lock mechanism. They are held in place by two or three rivets that you will need to drill out and replace with bolts.
These don't go out without a reason, I learned. Both my locks were pretty dry and very hard to operate. So I pulled them out too, cleaned them perfectly, lubricated and now I can lock/unlock the door with my pinky.
I'm sure somebody else will chime in here with more info and possibly a link.
Hope this helps.
Lou
1994.5 F350 5-sp 4WD CC LB 4.10, RanchHand bumpers, 35" BFG's;
VV 6.0L turbo, 3" DP, 4" exhaust, el. fuel system, open element intake, onboard air with
, SD Intercooler ... (+ 20 other mods)
BigBadLou is offline
