Return hose for power steering pump - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-24-2018, 12:47 PM Thread Starter
The power steering return hose on my truck is leaking and was wondering if just the hose itself can be replaced, or does it require the entire line.
Top portion is just clamped on and not sure if it's the same where it connects to the metal line.
Sorry for the dumb question, but it would be easier if just the hose can be replaced. Thanks
'97 F-250 CC 4:10's, E4OD, US Gear DP, TYMAR element, pillar gauges JD coolant eye, Mobil 1 front and rear, nerf bars, Glastite cap, 2006 Rage'n 2600<font color="#OOFFOO">
azstroke is offline
post #2 of 3 (permalink) Old 12-24-2018, 06:44 PM
Steve83's Avatar
Yes, it's just common medium-pressure hydraulic hose (probably 3/8"). The factory swages the rubber onto the steel, but you can simply cut off the (usually Aluminum) swage, and replace the hose with a common clamp. But while you're at it, you should consider adding a filter (I prefer Magnefine):
(phone app link)
Steve83 is offline
post #3 of 3 (permalink) Old 12-24-2018, 09:52 PM Thread Starter
Thanks Steve, I was hoping that was the case.
azstroke is offline
