rpm's VS mph - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-23-2008, 12:29 PM Thread Starter
Farrellmh's Avatar
Send a message via AIM to Farrellmh
rpm's VS mph
hey all. Quick question, im just trying to figure out if my tranny is ok or not.. so i need all the help i can get.. !! anyway at 60 mph, im running almost 2k rpms in OD.... seemed kinda high... but new to this truck and setup.. so any advice would be great!! thanks all
Farrellmh is offline
post #2 of 7 (permalink) Old 03-23-2008, 12:36 PM
blageurt's Avatar
My Photos: (9)
What is your rear end ratio ? 3:73 , 4:11 ? The transmission has nothing to do with final drive unless you are not engaging the OD.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
blageurt is offline
post #3 of 7 (permalink) Old 03-23-2008, 01:49 PM Thread Starter
Farrellmh's Avatar
ok... how do i check the gear ratio. with out taking the cover off?.... i did it on my gmc but its easy to count teeth when you can see them...?
post #4 of 7 (permalink) Old 03-23-2008, 02:05 PM
STurbo90's Avatar
My Photos: (9)
you can check the door tag for the axle code, or see if there is a tag on the axle itself.
then look at the chart to see what ratio it is,
Automotive What is my Ford rear end ratio, do I have positraction
but with stock tires, in od at 2K & 60mph, I would say you have 4.10 rear.
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #5 of 7 (permalink) Old 03-23-2008, 02:28 PM
DIESELDUTTON's Avatar
Sounds like you have 4:10's, these trucks only had 4:10's or 3:55's. I have 3:55's and when I had 265's @ 2k I was at 67-68 mph. Now with 35's @ 2k I'm at 73-74 mph.
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #6 of 7 (permalink) Old 03-23-2008, 02:54 PM Thread Starter
Farrellmh's Avatar
i have 285/75/R16.... and ill go check the code right now... but i think the stock tire is like a 235/85/R16 i think ... would my tires make a big difference?
post #7 of 7 (permalink) Old 03-23-2008, 03:01 PM Thread Starter
Farrellmh's Avatar
my code is C5 .. so according to the chart i have a limited slip... with 4:10's ....
