Rust on inside of Rear diff cover - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 11-06-2018, 05:15 PM Thread Starter
I just pulled the cover off of my rear differential and found that the inside had a couple rust spots (see photo). The ring gear also has a few tiny spots of rust on a couple of the teeth. Should I put it back on like that or get a new cover? Thanks.
WillyD is offline
post #2 of 8 (permalink) Old 11-06-2018, 05:25 PM
bugman's Avatar
My Photos: (12)
I'd just take some steel wool and clean it up and reuse the cover.
Is the vent tube still attached to the rear diff? Have you even driven through some deep water where water could of gotten into the diff?
bugman is online now
post #3 of 8 (permalink) Old 11-06-2018, 05:44 PM Thread Starter
Haven't driven through any standing water since I've had it, not sure about prior use though. The vent tube is still attached. I'll put some Emery cloth to it and reuse it. Thanks.
WillyD is offline
post #4 of 8 (permalink) Old 11-07-2018, 10:29 AM
Steve83's Avatar
Note that those spots are above the oil line, so they happened when the truck was parked for a long time. The oil eventually ran down, and condensation due to weather changes caused the rust. I'd degrease & wash it thoroughly a few times, and either apply primer/sealer or galvanizing compound before reinstalling it. But even with no remedial action, the cover will last decades more.
Steve83 is offline
post #5 of 8 (permalink) Old 11-07-2018, 09:23 PM
ArcticDriver's Avatar
Originally Posted by Steve83 View Post
... and either apply primer/sealer or galvanizing compound before reinstalling it. But even with no remedial action, the cover will last decades more.
Would you have to be concerned about primer/paint or galvinizing compound deteriorating with constant gear oil exposure?
SOLD:
ArcticDriver is offline
post #6 of 8 (permalink) Old 11-07-2018, 11:34 PM Thread Starter
I'll keep that in mind when I do the front differential. I've already reinstalled the cover on the rear, but I did degrease it and clean it up with some emery cloth. Thanks.
WillyD is offline
post #7 of 8 (permalink) Old 11-08-2018, 09:28 AM
Steve83's Avatar
Not if it's allowed to dry thoroughly before installation. But if there's gear oil on those spots, they won't continue to rust.
Steve83 is offline
post #8 of 8 (permalink) Old 11-08-2018, 10:07 AM
bugman's Avatar
My Photos: (12)
I figured that since the truck is 21-24 years old and the possibility of it seeing another 21-24 years that why worry when the factory didn't do anything to protect it. Odds are that rear end cover will out live the truck with nothing being done.
