Smoke/steam from valve cover. No pressure - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-17-2019, 10:50 AM Thread Starter
I have had my truck for one year, got her with 206k on the clock and she’s been a damn good truck. For as long as I have had her she has had smoke coming from the dipstick and the valve cover. It has no noticeable amount of pressure pushing it out. I’m one of those people that want there vehicles at the best they can be and this has been one thing I haven’t been able to track down. I assumed blow by but I have done all the shade tree mechanic tests, flipped the cap and it doesn’t move at all, used a paper towel and laid it on top and it also doesn’t move whatsoever. It will alternate between the cap and the dipstick tub, remove the cap and it’s coming from the cover. Cover the hole or put the cap back and it moves to the dip stick. The only think I can assume it would be is moisture or oil being burnt internally from a leaky o-ring on a injector (if that’s possible) I have quite a few friends who work on diesels for a living and I get mixed opinions. Some say blow by, others say it’s normal for a 7.3 to do this, and one says it may been getting water in the cylinder from a internal head gasket leak (he said it’s not likely but has seen it happen before) it only happens when she gets up to temp. I’m leaning more towards the leaky o-ring or cracked injector cup for the simple fact that occosionally when I give her the beans I can smell a mix of burnt oil and fuel. It has the original injectors according to all the previous owners, I have met and talked to all of them. Though I don’t trust them because they all want the truck back something serious. I’d appreciate any advice you 7.3 vets got for me, this is the first diesel I have owned personally and the oldest one I have experience with and it’s night and days difference from 6.0s.
Austin_ce is offline
post #2 of 4 (permalink) Old 03-17-2019, 11:00 AM
Patrick Feeley's Avatar
My Photos: (19)
If you do have a cracked injector cup, you should see fuel in the coolant. You might send an oil sample out for analysis (someone like Blackstone) and see if it shows fuel or coolant in it. If there is water/coolant in the oil it should look like a milkshake. Short of doing a compression test and removing injectors to check the cups (and replace O-rings while you're at it), there not much else to do. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 03-18-2019, 12:09 AM Thread Starter
there is definitely no mixture of oil or coolant or diesel of any sort, the oil is black as night, and the coolant is just coolant. I know this for a fact cause shortly after I posted this my water pump took a **** on me and poured most of it out on my driveway 😂 funny how everytime you brag about em they kick ya in the balls. How about bad o-rings? Seems like a possible culprit
post #4 of 4 (permalink) Old 03-18-2019, 08:24 PM
My Photos: (19)
You'll always get some oil vapor out the engine and you'll also get some condensation burning off as well as it warms up. As far as injector O-rings go, keep tabs on your oil usage. My only experience with an o-ring failure was my 94 using 8 quarts in 150 miles (right after an oil change at 175k). Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
Similar Threads
Valvebody or Shift Kit TestDiesel '99 & up Upgrades and Aftermarket - 7.3L Engine 22 08-29-2007 03:05 PM
Injector Help and More? Ckill Power Strokes 1994-1997 General 12 02-24-2007 11:03 AM
No start problem when no oil pressure on guage? CarterKraft '99 & up 7.3L Power Stroke Engine and Drivetrain 10 12-21-2005 04:19 PM
Big Ford Fuel-Related Part Numbers Post DaveBey Power Strokes 1994-1997 General 4 12-07-2005 02:06 PM
master brake cylinder leaking chumstone 6.9L IDI Diesels (Not Power Strokes) 10 06-27-2005 11:17 AM
